Datasheet ADR3525, ADR3530, ADR3533, ADR3540, ADR3550 (Analog Devices)
Description | Micropower, Precision, Auto Qualified 5.0V Voltage Reference |
Pages / Page | 20 / 1 — Micropower, High Accuracy. Voltage References. Data Sheet. ADR3525/. … |
Revision | B |
File Format / Size | PDF / 789 Kb |
Micropower, High Accuracy. Voltage References. Data Sheet. ADR3525/. ADR3530/. ADR3533. /ADR3540/. ADR3550. FEATURES. PIN CONFIGURATION
Micropower, High Accuracy Voltage References Data Sheet ADR3525/ ADR3530/ ADR3533 /ADR3540/ ADR3550 FEATURES PIN CONFIGURATION Maximum temperature coefficient: 5 ppm/°C (B grade) ENABLE 1 8 V Low long-term drift (LTD): 30 ppm (initial 1 khr typical) IN GND SENSE ADR35xx 2 7 VOUT SENSE Initial output voltage error: ±0.1% (maximum) TOP VIEW GND FORCE 3 6 VOUT FORCE (Not to Scale) Operating temperature range: −40°C to +125°C NC 4 5 NC Output current: +10 mA source/−3 mA sink NOTES
-001
Low quiescent current: 100 μA (maximum) 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
09594
Low dropout voltage: 250 mV at 2 mA
Figure 1. 8-Lead MSOP (RM-8 Suffix)
Output voltage noise (0.1 Hz to 10 Hz): 29 μV p-p at 4.096 V (typical) Qualified for automotive applications APPLICATIONS Automotive battery monitors Portable instrumentation Process transmitters Remote sensors Medical instrumentation GENERAL DESCRIPTION
The ADR3525W, ADR3530W, ADR3533W, ADR3540W, and
Table 1. Selection Guide
ADR3550W are low cost, low power, high precision CMOS
Model Output Voltage (V) Input Voltage Range (V)
voltage references, featuring a maximum temperature coeffi- ADR3525W 2.500 2.7 to 5.5 cient (TC) of 5 ppm/°C (B grade), 8 ppm/°C (A grade), low ADR3530W 3.000 3.2 to 5.5 operating current, and low output noise in an 8-lead MSOP ADR3533W 3.300 3.5 to 5.5 package. For high accuracy, the output voltage and temperature ADR3540W 4.096 4.3 to 5.5 coefficient are trimmed digitally during final assembly using the ADR3550W 5.000 5.2 to 5.5 Analog Devices, Inc., proprietary DigiTrim® technology. The low output voltage hysteresis and low long-term output voltage drift improve lifetime system accuracy. These CMOS references are available in five output voltages, all of which are specified over the automotive temperature range of −40°C to +125°C.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2011–2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Pin Configuration General Description Revision History Specifications ADR3525 Electrical Characteristics ADR3530 Electrical Characteristics ADR3533 Electrical Characteristics ADR3540 Electrical Characteristics ADR3550 Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation Long-Term Output Voltage Drift Power Dissipation Applications Information Basic Voltage Reference Connection Input and Output Capacitors 4-Wire Kelvin Connections VIN Slew Rate Considerations Shutdown/Enable Feature Sample Applications Negative Reference Bipolar Output Reference Boosted Output Current Reference Outline Dimensions Ordering Guide Automotive Products
