Datasheet ADR130 (Analog Devices) - 8
Description | Precision Series Sub-Band Gap Voltage Reference |
Pages / Page | 16 / 8 — ADR130. Data Sheet. 0.05. 0.08. 0.07. /mA). 0.04. 0.06. URCE. 0.03. N–S. … |
Revision | D |
File Format / Size | PDF / 629 Kb |
ADR130. Data Sheet. 0.05. 0.08. 0.07. /mA). 0.04. 0.06. URCE. 0.03. N–S. 0.02. 0.01. AD RE. –40. –25. –10. 110. 125. TEMPERATURE (°C). 1.0. 2.0. 0.9. 1.8. 0.8. 1.6. 0.7. 1.4
ADR130 Data Sheet 0.05 0.08 0.07 /mA) 0.04 /mA) mV mV 0.06 ( ( URCE 0.05 0.03 URCE O O N–S N–S 0.04 IO IO AT 0.02 AT 0.03 UL UL G G 0.02 0.01 AD RE AD RE O O L L 0.01
014 017
0
06322-
0
06322-
–40 –25 –10 5 20 35 50 65 80 95 110 125 –40 –25 –10 5 20 35 50 65 80 95 110 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 14. Load Regulation (Source) vs. Temperature, VOUT = 0.5 V Figure 17. Load Regulation (Source) vs. Temperature, VOUT = 1 V
1.0 2.0 0.9 1.8 0.8 1.6 /mA) /mA) mV 0.7 mV 1.4 INK ( 0.6 INK ( 1.2 N–S N–S IO 0.5 IO 1.0 AT AT 0.4 0.8 UL UL G G 0.3 0.6 AD RE AD RE O 0.2 O 0.4 L L 0.1
015
0.2
018 06322-
0
06322-
0 –40 –25 –10 5 20 35 50 65 80 95 110 125 –40 –25 –10 5 20 35 50 65 80 95 110 125 TEMPERATURE (°C) TEMPERATURE (°C)
Figure 15. Load Regulation (Sink) vs. Temperature, VOUT = 0.5 V Figure 18. Load Regulation (Sink) vs. Temperature, VOUT = 1 V
CIN = COUT = 0.1µF CIN = COUT = 0.1µF CH1 PEAK-TO-PEAK 5.72µV CH1 PEAK-TO-PEAK 3.16µV V V /DI /DI V V 2µ 2µ
016 019 06322- 06322-
TIME (1s/DIV) TIME (1s/DIV)
Figure 16. 0.1 Hz to 10 Hz Noise, VOUT = 0.5 V Figure 19. 0.1 Hz to 10 Hz Noise, VOUT = 1 V Rev. C | Page 8 of 16 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Terminology Theory of Operation Power Dissipation Considerations Input Capacitor Output Capacitor Application Notes Basic Voltage Reference Connection Stacking Reference ICs for Arbitrary Outputs Precision Current Source Outline Dimensions Ordering Guide
