Datasheet LT6660 (Analog Devices) - 6
Description | Tiny Micropower Precision Series References in 2mm × 2mm DFN |
Pages / Page | 12 / 6 — TYPICAL PERFOR A CE CHARACTERISTICS Characteristic curves are similar for … |
File Format / Size | PDF / 415 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS Characteristic curves are similar for all voltage
LT6660
W U TYPICAL PERFOR A CE CHARACTERISTICS Characteristic curves are similar for all voltage options of the LT6660. Curves from the LT6660-2.5 and the LT6660-10 represent the extremes of the voltage options. Characteristic curves for other output voltages fall between these curves, and can be estimated based on their voltage output. 10V Minimum Input-Output Voltage Differential 10V Load Regulation, Sourcing 10V Load Regulation, Sinking
100 35 250 30 25 200 125°C 10 125°C 20 150 15 25°C 25°C 10 –55°C 100 1 5 –55°C OUTPUT CURRENT (mA) 0 –55°C OUTPUT VOLTAGE CHANGE (mV) 50 OUTPUT VOLTAGE CHANGE (mV) –5 125°C 25°C 0.1 –10 0 0 0.5 1.0 1.5 2.0 2.5 0.1 1 10 100 0 1 2 3 4 5 INPUT-OUTPUT VOLTAGE (V) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 6660 G12 6660 G13 6660 G14
10V Output Voltage 10V Supply Current Temperature Drift vs Input Voltage 10V Line Regulation
10.006 350 10.010 THREE TYPICAL PARTS 10.004 300 10.002 10.005 25°C 10.000 250 25°C 9.998 (µA) 125°C 10.000 –55°C 9.996 200 –55°C 9.994 9.995 125°C 9.992 150 9.990 9.990 OUTPUT VOLTAGE (V) SUPPLY CURRENT 100 OUTPUT VOLTAGE (V) 9.988 9.986 50 9.985 9.984 9.982 0 9.980 –50 –25 0 25 50 75 100 125 0 2 4 6 8 10 12 14 16 18 20 6 8 10 12 14 16 18 20 TEMPERATURE (°C) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 6660 G15 6660 G16 6660 G17 6660fa 6
