Datasheet ADR03-EP (Analog Devices) - 3
DescriptionUltracompact, Precision 2.5 V Voltage Reference
Pages / Page6 / 3 — Enhanced Product. ADR03-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. …
File Format / SizePDF / 166 Kb
Enhanced Product. ADR03-EP. SPECIFICATIONS ELECTRICAL CHARACTERISTICS. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ
Enhanced Product ADR03-EP SPECIFICATIONS ELECTRICAL CHARACTERISTICS Table 1 Parameter Symbol Test Conditions/Comments Min Typ
Input voltage (VIN) = 4.5 V to 15.0 V, TA = 25°C, unless otherwise noted.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OUTPUT VOLTAGE VO 2.495 2.500 2.505 V INITIAL ACCURACY VOERR 5 mV 0.2 % TEMPERATURE COEFFICIENT TCVO −55°C < TA < +125°C 3 30 ppm/°C DROPOUT VOLTAGE VDO 2 V REGULATION Line ∆VO/∆VIN VIN = 4.5 V to 15.0 V, −55°C < TA < +125°C 7 40 ppm/V Load ∆VO/∆ILOAD Load current (ILOAD) = 0 mA to 10 mA, −55°C < 45 80 ppm/mA TA < +125°C, VIN = 7.0 V QUIESCENT CURRENT IIN No load, −55°C < TA < +125°C 0.65 1 mA VOLTAGE NOISE eN p-p 0.1 Hz to 10.0 Hz 6 µV p-p Density eN 1 kHz 230 nV/√Hz TURN-ON SETTLING TIME tR 4 µs LONG-TERM STABILITY1 ∆VO 1000 hours 50 ppm OUTPUT VOLTAGE HYSTERESIS ∆VO_HYS 70 ppm −55°C < TA < +125°C 80 ppm RIPPLE REJECTION RATIO RRR Input frequency (fIN) = 10 kHz –75 dB SHORT CIRCUIT TO GND ISC 30 mA TEMPERATURE SENSOR Voltage Output at TEMP Pin VTEMP 550 mV Temperature Sensitivity TCVTEMP 1.96 mV/°C 1 The long-term stability specification is noncumulative. The drift in subsequent 1000 hour periods is significantly lower than in the first 1000 hour period. Rev. 0 | Page 3 of 6 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
