Datasheet LT1460 (Analog Devices) - 5
Description | Micropower Precision Series Reference Family |
Pages / Page | 26 / 5 — The. denotes the specifications which apply over the full operating |
File Format / Size | PDF / 1.1 Mb |
LT1460 electrical characteristics
The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = VOUT + 2.5V, IOUT = 0 unless otherwise specified. PARAMETER CONDITIONS MIN TYP MAX UNITS
Output Voltage LT1460ACN8-2.5, ACS8-2.5 2.49813 2.50188 V –0.075 0.075 % LT1460BIN8-2.5, BIS8-2.5, CCMS8-2.5, 2.4975 2.5025 V DCN8-2.5, DCS8-2.5 –0.10 0.10 % LT1460EIN8-2.5, EIS8-2.5 2.49688 2.50313 V –0.125 0.125 % LT1460FCMS8-2.5 2.49625 2.50375 V –0.15 0.15 % LT1460GCZ-2.5, GIZ-2.5 2.49375 2.50625 V –0.25 0.25 % LT1460LHS8-2.5, MHS8-2.5 2.495 2.505 V –0.20 0.20 % LT1460ACN8-5, ACS8-5 4.99625 5.00375 V –0.075 0.075 % LT1460BIN8-5, BIS8-5, CCMS8-5, 4.995 5.005 V DCN8-5, DCS8-5 –0.10 0.10 % LT1460EIN8-5, EIS8-5 4.99375 5.00625 V –0.125 0.125 % LT1460FCMS8-5 4.9925 5.0075 V –0.15 0.15 % LT1460GCZ-5, GIZ-5 4.9875 5.0125 V –0.25 0.25 % LT1460LHS8-5, MHS8-5 4.990 5.010 V –0.20 0.20 % LT1460ACN8-10, ACS8-10 9.9925 10.0075 V –0.075 0.075 % LT1460BIN8-10, BIS8-10, CCMS8-10, 9.990 10.010 V DCN8-10, DCS8-10 –0.10 0.10 % LT1460EIN8-10, EIS8-10 9.9875 10.0125 V –0.125 0.125 % LT1460FCMS8-10 9.985 10.0015 V –0.15 0.15 % LT1460GCZ-10, GIZ-10 9.975 10.025 V –0.25 0.25 % LT1460HC –0.2 0.2 % LT1460JC –0.4 0.4 % LT1460KC –0.5 0.5 % Output Voltage Temperature Coefficient (Note 3) TMIN ≤ TJ ≤ TMAX LT1460ACN8, ACS8, BIN8, BIS8 l 5 10 ppm/°C LT1460CCMS8 l 7 15 ppm/°C LT1460DCN8, DCS8, EIN8, EIS8 l 10 20 ppm/°C LT1460FCMS8, GCZ, GIZ l 12 25 ppm/°C LT1460LHS8 –40°C to 85°C l 10 20 ppm/°C –40°C to 125°C l 25 50 ppm/°C LT1460MHS8 –40°C to 125°C l 25 50 ppm/°C LT1460HC l 10 20 ppm/°C LT1460JC l 10 20 ppm/°C LT1460KC l 25 50 ppm/°C 1460fc Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
