Datasheet LT1460 (Analog Devices) - 8
Description | Micropower Precision Series Reference Family |
Pages / Page | 26 / 8 — LT1460-2.5 (N8, S8, MS8, Z Packages). 2.5V Minimum Input-Output. Voltage … |
LT1460-2.5 (N8, S8, MS8, Z Packages). 2.5V Minimum Input-Output. Voltage Differential. 2.5V Load Regulation, Sourcing
LT1460 typical perForMance characteristics
LT1460-2.5 (N8, S8, MS8, Z Packages) 2.5V Minimum Input-Output Voltage Differential 2.5V Load Regulation, Sourcing 2.5V Load Regulation, Sinking
100 6 80 70 5 125°C 60 125°C 10 4 50 25°C 3 –55°C 40 25°C 125°C 25°C 30 1 2 OUTPUT CURRENT (mA) 20 –55°C OUTPUT VOLTAGE CHANGE (mV) 1 OUTPUT VOLTAGE CHANGE (mV) –55°C 10 0.1 0 0 0 0.5 1.0 1.5 2.0 2.5 0.1 1 10 100 0 0.5 1.0 1.5 INPUT-OUTPUT VOLTAGE (V) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 1460 G01 1460 G02 1460 G03
2.5V Output Voltage 2.5V Supply Current vs Input Temperature Drift Voltage 2.5V Line Regulation
2.503 175 2.5014 3 TYPICAL PARTS 150 125°C 125°C 2.502 2.5010 125 25°C 2.5006 2.501 100 25°C 2.5002 75 –55°C 2.500 2.4998 OUTPUT VOLTAGE (V) 50 SUPPLY CURRENT (µA) OUTPUT VOLTAGE (V) –55°C 2.499 25 2.4994 2.498 0 2.4990 –50 –25 0 25 50 75 100 0 5 10 15 20 0 2 4 6 8 10 12 14 16 18 20 TEMPERATURE (°C) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 1460 G04 1460 G05 1460 G06
2.5V Power Supply Rejection 2.5V Output Impedance vs Ratio vs Frequency Frequency 2.5V Transient Responses
90 1k 80 CL= 0.1µF 10 70 60 CL = 0 1 100 50 40 0.1 30 LOAD CAPACITANCE (µF) 10 20 0 OUTPUT IMPEDANCE (Ω) 10 I 1460 G09 OUT = 10mA POWER SUPPLY REJECTION RATIO (dB) 0 CL= 1µF –10 1 100 1k 10k 100k 1M 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) 1460 G07 1460 G08 1460fc Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
