Datasheet REF198x (Analog Devices) - 8
Description4.096V Precision Micropower, Low Dropout, Low Voltage Reference
Pages / Page28 / 8 — REF19x Series. Data Sheet. ELECTRICAL CHARACTERISTICS—REF193 @ TA = 25°C. …
RevisionL
File Format / SizePDF / 509 Kb
REF19x Series. Data Sheet. ELECTRICAL CHARACTERISTICS—REF193 @ TA = 25°C. Table 8. Parameter Symbol. Condition. Min. Typ. Max. Unit
REF19x Series Data Sheet ELECTRICAL CHARACTERISTICS—REF193 @ TA = 25°C Table 8 Parameter Symbol Condition Min Typ Max Unit
link to page 20 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8
@ VS = 3.3 V, TA = 25°C, unless otherwise noted.
Table 8. Parameter Symbol Condition Min Typ Max Unit
INITIAL ACCURACY1 VO G Grade IOUT = 0 mA 2.990 3.0 3.010 V LINE REGULATION2 ΔVO/ΔVIN G Grade 3.3 V, ≤ VS ≤ 15 V, IOUT = 0 mA 4 8 ppm/V LOAD REGULATION2 ΔVO/ΔVLOAD G Grade VS = 5.0 V, 0 mA ≤ IOUT ≤ 30 mA 6 15 ppm/mA DROPOUT VOLTAGE VS − VO VS = 3.8 V, ILOAD = 10 mA 0.80 V VS = 4.0 V, ILOAD = 30 mA 1.00 V LONG-TERM STABILITY3 DVO 1000 hours @ 125°C 1.2 mV NOISE VOLTAGE eN 0.1 Hz to 10 Hz 30 μV p-p 1 Initial accuracy does not include shift due to solder heat effect (see the Applications Information section). 2 Line and load regulation specifications include the effect of self-heating. 3 Long-term stability specification is noncumulative. The drift in subsequent 1000-hour periods is significantly lower than in the first 1000-hour period.
ELECTRICAL CHARACTERISTICS—REF193 @ −40°C ≤ TA ≤ +85°C
@ VS = 3.3 V, TA = −40°C ≤ TA ≤ +85°C, unless otherwise noted.
Table 9. Parameter Symbol Condition Min Typ Max Unit
TEMPERATURE COEFFICIENT1, 2 TCVO/°C G Grade3 IOUT = 0 mA 10 25 ppm/°C LINE REGULATION4 ΔVO/ΔVIN G Grade 3.3 V ≤ VS ≤ 15 V, IOUT = 0 mA 10 20 ppm/V LOAD REGULATION4 ΔVO/ΔVLOAD G Grade VS = 5.0 V, 0 mA ≤ IOUT ≤ 25 mA 10 20 ppm/mA DROPOUT VOLTAGE VS − VO VS = 3.8 V, ILOAD = 10 mA 0.80 V VS = 4.1 V, ILOAD = 30 mA 1.10 V SLEEP PIN Logic High Input Voltage VH 2.4 V Logic High Input Current IH −8 μA Logic Low Input Voltage VL 0.8 V Logic Low Input Current IL −8 μA SUPPLY CURRENT No load 45 μA Sleep Mode No load 15 μA 1 For proper operation, a 1 μF capacitor is required between the output pin and the GND pin of the device. 2 TCVO is defined as the ratio of output change with temperature variation to the specified temperature range expressed in ppm/°C. TCVO = (VMAX − VMIN)/VO(TMAX − TMIN) 3 Guaranteed by characterization. 4 Line and load regulation specifications include the effect of self-heating. Rev. L | Page 8 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TEST PINS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—REF191 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF191 @ −40°C ≤ +85°C ELECTRICAL CHARACTERISTICS—REF191 @ −40°C ≤ TA ≤ +125°C ELECTRICAL CHARACTERISTICS—REF192 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF192 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF192 @ −40°C ≤ TA ≤ +125°C ELECTRICAL CHARACTERISTICS—REF193 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF193 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF193 @ TA ≤ −40°C ≤ +125°C ELECTRICAL CHARACTERISTICS—REF194 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF194 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF194 @ −40°C ≤ TA ≤ +125°C ELECTRICAL CHARACTERISTICS—REF195 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF195 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF195 @ −40°C ≤ TA ≤ +125°C ELECTRICAL CHARACTERISTICS—REF196 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF196 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF196 @ −40°C ≤ TA ≤ +125°C ELECTRICAL CHARACTERISTICS—REF198 @ TA = 25°C ELECTRICAL CHARACTERISTICS—REF198 @ −40°C ≤ TA ≤ +85°C ELECTRICAL CHARACTERISTICS—REF198 @ −40°C ≤ TA ≤ 125°C ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT SHORT-CIRCUIT BEHAVIOR DEVICE POWER DISSIPATION CONSIDERATIONS OUTPUT VOLTAGE BYPASSING SLEEP MODE OPERATION BASIC VOLTAGE REFERENCE CONNECTIONS MEMBRANE SWITCH-CONTROLLED POWER SUPPLY SOLDER HEAT EFFECT CURRENT-BOOSTED REFERENCES WITH CURRENT LIMITING NEGATIVE PRECISION REFERENCE WITHOUT PRECISION RESISTORS STACKING REFERENCE ICs FOR ARBITRARY OUTPUTS PRECISION CURRENT SOURCE SWITCHED OUTPUT 5 V/3.3 V REFERENCE KELVIN CONNECTIONS FAIL-SAFE 5 V REFERENCE LOW POWER, STRAIN GAGE CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
