link to page 7 link to page 7 link to page 7 AD680 In some applications, a varying load may be both resistive and 500 μ V50 μ s capacitive in nature, or the load may be connected to the 100 AD680 by a long capacitive cable. 90+VIN500 μ VVOUT0.1 μ FAD680VOUT249 Ω 10VVOUTL0%0V 00813-009 Figure 9. Transient Load Test Circuit 00813-007 Figure 7. Broadband Noise at 300 kHz TURN-ON TIME2V50mV5 μ s Upon application of power (cold start), the time required for 100VL 90 the output voltage to reach its final value within a specified error band is defined as the turn-on settling time. Two components normally associated with this are the time for the active circuits to settle, and the time for the thermal gradients on the chip to VOUT stabilize. The turn-on settling time of the AD680 is about 20 μs to within 0.025% of its final value, as shown in Figure 8. 105V1mV10 μ s0%100VIN90 00813-010 Figure 10. Large Scale Transient Response VOUT2V5mV5 μ s10100V0%IN90 00813-008 Figure 8. Turn-On Settling Time VOUT The AD680 thermal settling characteristic benefits from its compact design. Once initial turn-on is achieved, the output linearly approaches its final value; the output is typically within 10 0.01% of its final value after 25 ms. 0%DYNAMIC PERFORMANCE 00813-011 The output stage of the amplifier is designed to provide the Figure 11. Fine Scale Settling for Transient Load AD680 with static and dynamic load regulation superior to less complete references. Figure 9 to Figure 11 display the char- acteristics of the AD680 output amplifier driving a 0 mA to 10 mA load. Longer settling times result if the reference is forced to sink any transient current. Rev. H | Page 7 of 12 Document Outline FEATURES GENERAL DESCRIPTION CONNECTION DIAGRAMS PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS OUTPUT PROTECTION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS THEORY OF OPERATION APPLYING THE AD680 NOISE PERFORMANCE TURN-ON TIME DYNAMIC PERFORMANCE LOAD REGULATION TEMPERATURE PERFORMANCE TEMPERATURE OUTPUT PIN DIFFERENTIAL TEMPERATURE TRANSDUCER LOW POWER, LOW VOLTAGE REFERENCE FOR DATA CONVERTERS 4.5 V REFERENCE FROM A 5 V SUPPLY VOLTAGE REGULATOR FOR PORTABLE EQUIPMENT OUTLINE DIMENSIONS ORDERING GUIDE
