Datasheet REF01, REF02, REF03 (Analog Devices) - 10
Description2.5 V Precision Voltage Reference
Pages / Page20 / 10 — REF01/REF02/REF03. Data Sheet. 0.70. TA = 25°C. 0.65. ( T. ( E. +125°C. …
RevisionM
File Format / SizePDF / 682 Kb
REF01/REF02/REF03. Data Sheet. 0.70. TA = 25°C. 0.65. ( T. ( E. +125°C. RRE. LTAG. 0.60. UT O. –40°C. S IE U. 0.55. DRO. +25°C. 0.50. LOAD CURRENT (mA). LTA
REF01/REF02/REF03 Data Sheet 0.70 TA = 25°C 0.65 ( T ( E +125°C RRE LTAG 0.60 UT O –40°C S IE U 0.55 DRO +25°C 0.50 LOAD CURRENT (mA) LTA
REF01/REF02/REF03 Data Sheet 5 0.70 TA = 25°C 4 A) 0.65 ) m V ( T ( E N 3 +125°C RRE LTAG 0.60 O CU V 2 NT UT O –40°C CE P S IE U 0.55 DRO Q 1 +25°C 0 0.50 0 2 4 6 8 10
2 19
0 2 4 6 8 10
0 -02 5- 75
LOAD CURRENT (mA)
37
LOAD CURRENT (mA)
03 00 0 Figure 19. REF01 Dropout Voltage vs. Load Current Figure 22. REF01 Quiescent Current vs. Load Current
6 ) 4 (V GE IV +125°C /D LTA V O V T –40°C OU 2 OP R D +25°C
23 0
0
5- 37
0 2 4 6 8 10 TIME (1s/DIV)
20 00 0 5-
LOAD CURRENT (mA)
037 0 Figure 20. REF02 Dropout Voltage vs. Load Current Figure 23. REF02 Typical Low-Frequency Voltage Noise (0.1 Hz to 10.0 Hz)
6 5 ) V 4 ( E V /DI +125°C V LTAG 3 O V 50µ T +25°C U O 2 P –40°C DRO 1
4 02 5-
0
37
0 2 4 6 8 10
1
TIME (1ms/DIV)
00 -02 75
LOAD CURRENT (mA)
03 0 Figure 21. REF03 Dropout Voltage vs. Load Current Figure 24. REF02 Typical Wideband Voltage Noise (10 Hz to 10 kHz) Rev. M | Page 10 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS REF01 SPECIFICATIONS REF02 SPECIFICATIONS REF03 SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION INPUT AND OUTPUT CAPACITORS OUTPUT ADJUSTMENT TEMPERATURE MONITORING LONG-TERM STABILITY BURN-IN POWER DISSIPATION APPLICATIONS INFORMATION BASIC REFERENCE APPLICATION LOW COST CURRENT SOURCE PRECISION CURRENT SOURCE WITH ADJUSTABLE OUTPUT PRECISION BOOSTED OUTPUT REGULATOR BIPOLAR VOLTAGE REFERENCE ADJUSTABLE REFERENCE WITH POSITIVE AND NEGATIVE SWING OUTLINE DIMENSIONS REF01 ORDERING GUIDE REF02 ORDERING GUIDE REF03 ORDERING GUIDE
