Datasheet AD586 (Analog Devices) - 8
DescriptionHigh Precision 5 V Reference
Pages / Page16 / 8 — AD586. 200. 10V. 1mS. VIN. N = 1. VOUT. NO CN. TURN-ON TIME. 1mV. 100mS. …
RevisionG
File Format / SizePDF / 484 Kb
AD586. 200. 10V. 1mS. VIN. N = 1. VOUT. NO CN. TURN-ON TIME. 1mV. 100mS. DYNAMIC PERFORMANCE. 3.5V. 500
AD586 200 10V 1mS VIN N = 1 VOUT NO CN TURN-ON TIME 1mV 100mS DYNAMIC PERFORMANCE 3.5V 500
link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 9 link to page 9
AD586 200
µ
V 50
µ
S 10V 5V 1mS C VIN N = 1
µ
F VOUT NO CN
00529-007 00529-009 Figure 8. Effect of 1 µF Noise Reduction Capacitor on Broadband Noise Figure 10. Extended Time Scale
TURN-ON TIME 10V 1mV 100mS
Upon application of power (cold start), the time required for
VIN
the output voltage to reach its final value within a specified error band is defined as the turn-on settling time. Two compo- nents normally associated with this are the time for the active circuits to settle, and the time for the thermal gradients on the chip to stabilize. Figure 9, Figure 10, and Figure 11 show the turn-on characteristics of the AD586. It shows the settling to be
VOUT
about 60 µs to 0.01%. Note the absence of any thermal tails when the horizontal scale is expanded to l ms/cm in Figure 10. Output turn-on time is modified when an external noise reduc- 00529-010 tion capacitor is used. When present, this capacitor acts as an additional load to the current source of the internal Zener Figure 11. Turn-On with 1µF CN Characteristics diode, resulting in a somewhat longer turn-on time. In the case of a 1 µF capacitor, the initial turn-on time is approximately
DYNAMIC PERFORMANCE
400 ms to 0.01% (see Figure 11). The output buffer amplifier is designed to provide the AD586 with static and dynamic load regulation superior to less com-
10V 1mV
plete references.
VIN
Many ADCs and DACs present transient current loads to the reference, and poor reference response can degrade the per- formance of the converter.
VOUT
Figure 12, Figure 13, and Figure 14 display the characteristics of the AD586 output amplifier driving a 0 mA to 10 mA load.
VOUT 20
µ
S 3.5V 500
Ω 00529-008
5V AD586 VL
Figure 9. Electrical Turn-On
0V
00529-011 Figure 12. Transient Load Test Circuit Rev. G | Page 8 of 16 Document Outline FEATURES GENERAL DESCRIPTION PRODUCT HIGHLIGHTS SPECIFICATIONS AD586J, AD586K/AD586A, AD586L/AD586B AD586M, AD586S, AD586T ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS THEORY OF OPERATION APPLYING THE AD586 NOISE PERFORMANCE AND REDUCTION TURN-ON TIME DYNAMIC PERFORMANCE LOAD REGULATION TEMPERATURE PERFORMANCE NEGATIVE REFERENCE VOLTAGE FROM AN AD586 USING THE AD586 WITH CONVERTERS 5 V REFERENCE WITH MULTIPLYINGCMOS DACs OR ADCs STACKED PRECISION REFERENCES FORMULTIPLE VOLTAGES PRECISION CURRENT SOURCE PRECISION HIGH CURRENT SUPPLY OUTLINE DIMENSIONS ORDERING GUIDE
