Datasheet AD584 (Analog Devices) - 5
DescriptionPin Programmable Precision Voltage Reference
Pages / Page12 / 5 — Data Sheet. AD584. ABSOLUTE MAXIMUM RATINGS. Table 3. ESD CAUTION. …
RevisionC
File Format / SizePDF / 520 Kb
Data Sheet. AD584. ABSOLUTE MAXIMUM RATINGS. Table 3. ESD CAUTION. Parameter. Rating
Data Sheet AD584 ABSOLUTE MAXIMUM RATINGS Table 3 ESD CAUTION Parameter Rating
Data Sheet AD584 ABSOLUTE MAXIMUM RATINGS Table 3. ESD CAUTION Parameter Rating
Input Voltage VIN to Ground 40 V Power Dissipation at 25°C 600 mW Operating Junction Temperature Range −55°C to +125°C Lead Temperature (Soldering 10 sec) 300°C Thermal Resistance Junction-to-Ambient (H-08A) 150°C/W Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. C | Page 5 of 12 Document Outline Features General Description Pin Configurations Product Highlights Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Theory of Operation Applying the AD584 Performance over Temperature Output Current Characteristics Dynamic Performance Noise Filtering Using the Strobe Terminal Percision High Current Supply The AD584 as a Current Limiter Negative Reference Voltages from an AD584 10 V Reference with Multiplying CMOS DACs or ADCs Precision DAC Reference Outline Dimensions Ordering Guide
