Datasheet AD581 (Analog Devices) - 4
DescriptionHigh Precision 10 V IC Reference
Pages / Page12 / 4 — AD581. Table 2. AD581S AD581T AD581U. Model. Min. Typ. Max Min. Max …
RevisionC
File Format / SizePDF / 330 Kb
AD581. Table 2. AD581S AD581T AD581U. Model. Min. Typ. Max Min. Max Units. ±30. ±10. ±15. 3.0. 1.0. 500
AD581 Table 2 AD581S AD581T AD581U Model Min Typ Max Min Max Units ±30 ±10 ±15 3.0 1.0 500
link to page 4 link to page 4 link to page 7
AD581 Table 2. AD581S AD581T AD581U Model Min Typ Max Min Typ Max Min Typ Max Units
OUTPUT VOLTAGE TOLERANCE (Error from Nominal 10,000 V Output)
±30 ±10 ±5
mV OUTPUT VOLTAGE CHANGE Maximum Deviation from +25°C
±30 ±15 ±10
mV Value, TMIN to TMAX Temperature Coefficient 30 15 10 ppm/°C LINE REGULATION 15 V ≤ VIN ≤ 30 V
3.0 3.0 3.0
mV (0.002) (0.002) (0.002) %/V 13 V ≤ VIN ≤ 15 V
1.0 1.0 1.0
mV (0.005) (0.005) (0.005) %/V LOAD REGULATION 0 ≤ IOUT ≤ 5 mA 200
500
200
500
200
500
μV/mA QUIESCENT CURRENT 0.75
1.0
0.75
1.0
0.75
1.0
mA TURN-ON SETTLING TIME TO 0.1%1 200 200 200 μs NOISE (0.1 Hz TO 10 Hz) 40 40 40 μV (p-p) LONG-TERM STABILITY 25 25 25 ppm/1000 hr SHORT-CIRCUIT CURRENT 30 30 30 mA OUTPUT CURRENT Source @ +25°C 10 10 10 mA Source TMIN to TMAX 5 5 5 mA Sink TMIN to TMAX 200 200 200 μA Sink −55°C to +85°C 5 5 5 mA TEMPERATURE RANGE Specified −55 +125 −55 +125 −55 +125 °C Operating −65 +150 −65 +150 −65 +150 °C PACKAGE OPTION2 TO-5 (H-03B) AD581SH AD581TH AD581UH 1 See Figur e 7. 2 H indicates hermetic metal can. Rev. C | Page 4 of 12 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION APPLYING THE AD581 VOLTAGE VARIATION vs. TEMPERATURE OUTPUT CURRENT CHARACTERISTICS DYNAMIC PERFORMANCE PRECISION HIGH CURRENT SUPPLY CONNECTION FOR REDUCED PRIMARY SUPPLY THE AD581 AS A CURRENT LIMITER NEGATIVE 10 V REFERENCE 10 V REFERENCE WITH MULTIPLYING CMOS DACs OR ADCs PRECISION 12-BIT DAC REFERENCE OUTLINE DIMENSIONS ORDERING GUIDE
