link to page 9 link to page 10 link to page 9 link to page 10 AD581THE AD581 AS A CURRENT LIMITER The AD581 represents an alternative to current limiter diodes ANALOG GND that require factory selection to achieve a desired current. This +VS approach often results in temperature coefficients of 1%/°C. 0.1µFAD581 V The AD581 approach is not limited to a defined set current OUT limit; it can be programmed from 0.75 mA to 5 mA with the GNDVREF insertion of a single external resistor. Of course, the minimum –10V voltage required to drive the connection is 13 V. The AD580, 1.2kΩ 5% 3 -01 which is a 2.5 V reference, can be used in this type of circuit 14 –15V 80 0 with compliance voltage down to 4.5 V. Figure 13. 2-Pin −10 V Reference 10 V REFERENCE WITH MULTIPLYING CMOS DACs+VOR ADCsS~ 10VAD581i = ___ + 0.75mA10V =V The AD581 is ideal for application with the entire AD7533 OUTR series of 10- and 12-bit multiplying CMOS DACs, especially for GNDR LOAD low power applications. It is equally suitable for the AD7574 8-bit ADC. In the standard hook-up, as shown in Figure 15, the +10 V reference is inverted by the amplifier/DAC configuration BOTTOM VIEW OF 10V PRECISION 2 01 to produce a 0 V to −10 V range. If an OP1177 amplifier is used, REFERENCE CIRCUIT 4- IN TO-5 CASE 01 08 total quiescent supply current is typically 2 mA. If a 0 V to +10 V Figure 12. A Two-Component Precision Current Limiter full-scale range is desired, the AD581 can be connected to the NEGATIVE 10 V REFERENCE CMOS DAC in its −10 V Zener mode, as shown in Figure 13 (the −10 VREF output is connected directly to the VREF IN of the The AD581 can also be used in a 2-pin Zener mode to provide a CMOS DAC). The AD581 is normally used in the −10 V mode precision −10.00 V reference. As shown in Figure 13, the +VS and with the AD7574 to give a 0 V to +10 V ADC range. This is VOUT pins are connected together to the high supply (in this shown in Figure 15. Bipolar output applications and other case, ground). The ground pin is connected through a resistor operating details can be found in the data sheets for the CMOS to the negative supply. Thus, the output is taken from the products. ground pin instead of VOUT. With 1 mA flowing through the +15V AD581 in this mode, a typical unit shows a 2 mV increase in output level over that produced in the 3-pin mode. Note also +10V that the effective output impedance in this connection increases AD581 from 0.2 Ω typical to 2 Ω. It is essential to arrange the output VREF IN load and the supply resistor, RS, so that the net current through BIT 1 (MSB)1514RFEEDBACK the AD581 is always between 1 mA and 5 mA. For operation to 416DIGITAL+15V5 +125°C, the net current should be between 2 mA and 5 mA. The INPUTIOUT11 temperature characteristics and long-term stability of the device VOUT0V TO –10V are essentially the same as that of a unit used in the standard IOUT2 3-pin mode. 132–15VBIT 10 (LSB)3 14 0 GND 4- The AD581 can also be used in a 2-pin mode to develop a 01 08 positive reference. +VS and VOUT are tied together and to the Figure 14. Low Power 10-Bit CMOS DAC Application positive supply through an appropriate supply resistor. The PRECISION 12-BIT DAC REFERENCE performance characteristics are similar to those of the negative 2-pin connection. The only advantage of this connection over AD565A, like most DACs, is designed to operate with a +10 V the standard 3-pin connection is that a lower primary supply reference element. In the AD565A, this 10 V reference voltage is can be used, as low as 10.5 V. This type of operation requires con- converted into a reference current of approximately 0.5 mA via siderable attention to load and primary supply regulation to the internal 19.95 kΩ resistor (in series with the external 100 Ω maintain the AD581 within its regulating range of 1 mA to 5 mA trimmer). The gain temperature coefficient of the AD565A is (2 mA to 5 mA for operation beyond +85°C). primarily governed by the temperature tracking of the 19.95 kΩ resistor and the 5 kΩ to10 kΩ span resistors; gain TC is guaran- teed to 3 ppm/°C. Thus, using the AD581L (at 5 ppm/°C) as the Rev. C | Page 9 of 12 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION APPLYING THE AD581 VOLTAGE VARIATION vs. TEMPERATURE OUTPUT CURRENT CHARACTERISTICS DYNAMIC PERFORMANCE PRECISION HIGH CURRENT SUPPLY CONNECTION FOR REDUCED PRIMARY SUPPLY THE AD581 AS A CURRENT LIMITER NEGATIVE 10 V REFERENCE 10 V REFERENCE WITH MULTIPLYING CMOS DACs OR ADCs PRECISION 12-BIT DAC REFERENCE OUTLINE DIMENSIONS ORDERING GUIDE
