Datasheet AD580 (Analog Devices) - 8
Description | High Precision 2.5 V IC Reference |
Pages / Page | 8 / 8 — AD580. OUTLINE DIMENSIONS. 0.500 (12.70). 0.150 (3.81). MIN. 0.115 … |
Revision | B |
File Format / Size | PDF / 194 Kb |
AD580. OUTLINE DIMENSIONS. 0.500 (12.70). 0.150 (3.81). MIN. 0.115 (2.92). 0.250 (6.35) MIN. 0.050 (1.27) T.P. 0.050 (1.27) MAX
AD580 OUTLINE DIMENSIONS 0.500 (12.70) 0.150 (3.81) MIN 0.115 (2.92) 0.250 (6.35) MIN 0.050 (1.27) T.P. 0.050 (1.27) MAX 0.048 (1.22) 3 0.028 (0.71) 0.100 5.84) 5.31) 4.95) 4.52) (2.54) 2 T.P. 0.046 (1.17) 0.230 ( 0.209 ( 0.195 ( 0.178 ( 1 0.036 (0.91) 0.019 (0.48) 0.050 (1.27) 0.016 (0.41) T.P. 0.030 (0.76) MAX 0.021 (0.53) MAX 45° T.P. BASE & SEATING PLANE CONTROLLING DIMENSIONS ARE IN INCHES; MILLIMETERS DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF INCH EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN
Figure 13. TO–52 Package Dimensions shown in inches and (millimeters)
ORDERING GUIDE Output Voltage Temperature Operating Package Model Tolerance Coefficient Temperature Range Package Option Description
AD580JH ±75 mV 85 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580KH ±25 mV 40 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580LH ±10 mV 25 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580LMH ±10 mV 10 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580SH ±25 mV 55 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580SH/883B ±25 mV 55 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580TH ±10 mV 25 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580UH ±10 mV 10 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580UH/883B ±10 mV 10 ppm/°C –55°C to +125°C TO–52 H (Metal Can) AD580TCHIPS ±10 mV DIE
© 2004 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. C00525-0-8/04(B)
Rev. B | Page 8 of 8 Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS AD580 CHIP DIMENSIONS AND PAD LAYOUT ESD CAUTION THEORY OF OPERATION VOLTAGE VARIATION VERSUS TEMPERATURE NOISE PERFORMANCE THE AD580 AS A CURRENT LIMITER THE AD580 AS A LOW POWER, LOW VOLTAGE, PRECISION REFERENCE F OUTLINE DIMENSIONS ORDERING GUIDE
