Datasheet LTM4630 (Analog Devices) - 5
DescriptionDual 18A or Single 36A DC/DC µModule Regulator
Pages / Page34 / 5 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 3:. Note 4:. Note 5:. Note 2:. …
File Format / SizePDF / 653 Kb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 3:. Note 4:. Note 5:. Note 2:. Note 6:. Note 7:. TYPICAL PERFORMANCE CHARACTERISTICS
ELECTRICAL CHARACTERISTICS Note 1: Note 3: Note 4: Note 5: Note 2: Note 6: Note 7: TYPICAL PERFORMANCE CHARACTERISTICS
LTM4630
Note 3:
Two outputs are tested separately and the same testing condition may cause permanent damage to the device. Exposure to any Absolute is applied to each output. Maximum Rating condition for extended periods may affect device
Note 4:
The switching frequency is programmable from 400kHz to 750kHz. reliability and lifetime.
Note 5:
LTM4630 device is designed to operate from 400kHz to 750kHz
Note 2:
The LTM4630 is tested under pulsed load conditions such that
Note 6:
These parameters are tested at wafer sort. TJ ≈ TA. The LTM4630E is guaranteed to meet specifications from 0°C to 125°C internal temperature. Specifications over the –40°C to
Note 7:
See output current derating curves for different VIN, VOUT and TA. 125°C internal operating temperature range are assured by design, characterization and correlation with statistical process controls. The LTM4630I is guaranteed over the full –40°C to 125°C internal operating temperature range. Note that the maximum ambient temperature consistent with these specifications is determined by specific operating conditions in conjunction with board layout, the rated package thermal impedance and other environmental factors.
TYPICAL PERFORMANCE CHARACTERISTICS Dual Phase Single Output Efficiency Efficiency vs Output Current, Efficiency vs Output Current, vs Output Current, VIN = 12V, VIN = 5V, fS = 450kHz VIN = 12V, fS = 450kHz fS = 450kHz
100 95 95 90 90 95 85 85 90 80 80 85 EFFICIENCY (%) EFFICIENCY (%) 75 EFFICIENCY (%) 75 V V 80 OUT = 1V OUT = 1V VOUT = 1V VOUT = 1.2V 70 VOUT = 1.2V 70 VOUT = 1.2V VOUT = 1.5V VOUT = 1.5V VOUT = 1.5V VOUT = 1.8V VOUT = 1.8V VOUT = 1.8V 75 65 65 0 2 4 6 8 10 12 14 16 18 0 2 4 6 8 10 12 14 16 18 0 5 10 15 20 25 30 35 40 LOAD CURRENT (A) LOAD CURRENT (A) LOAD CURRENT (A) 4630 G01 4630 G02 4630 G03
Burst Mode and Pulse-Skip Mode Efficiency VIN=12V, VOUT = 1.2V, 1V Single Phase Output Load 1.2V Single Phase Output Load fS = 450kHz Transient Response Transient Response
100 CCM Burst Mode OPERATION 90 PULSE-SKIP MODE 80 VOUT(AC) VOUT(AC) 50mV/Div 50mV/Div 70 60 EFFICIENCY (%) LOAD STEP LOAD STEP 50 2A/DIV 2A/DIV 40 4630 G05 4630 G06 20µs/DIV 20µs/DIV 12VIN, 1VOUT, 450kHz, 4.5A LOAD STEP, 12VIN, 1.2VOUT, 450kHz, 4.5A LOAD STEP, 30 4.5A/µs STEP-UP AND STEP-DOWN 4.5A/µs STEP-UP AND STEP-DOWN 0.01 0.1 1 10 COUT = 1 • 470µF 4V POSCAP + 1 • 100µF COUT = 1 • 470µF 4V POSCAP + 1 • 100µF LOAD CURRENT (A) 6.3V CERAMIC 6.3V CERAMIC 4630 G04 4630fa For more information www.linear.com/LTM4630 5 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Applications Information Package Description Related Parts
