Datasheet LTM4620A (Analog Devices) - 3
DescriptionDual 13A or Single 26A DC/DC µModule Regulator
Pages / Page40 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 725 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified internal
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified internal
LTM4620A
l
denotes the specifications which apply over the specified internal operating temperature range. Specified as each individual output channel. TA = 25°C (Note 2), VIN = 12V and VRUN1, VRUN2 at 5V unless otherwise noted. Per the typical application in Figure 26. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Input DC Voltage l 4.5 16 V VOUT Output Voltage (Note 8) l 0.6 5.3 V VOUT1(DC), Output Voltage, Total Variation with CIN = 22µF × 3, COUT = 100µF × 1 Ceramic, l 1.477 1.5 1.523 V VOUT2(DC) Line and Load 220µF POSCAP
Input Specifications
VRUN1, VRUN2 RUN Pin On/Off Threshold RUN Rising 1.1 1.25 1.40 V VRUN1HYS, VRUN2HYS RUN Pin On Hysteresis 150 mV IINRUSH(VIN) Input Inrush Current at Start-Up IOUT = 0A, CIN = 22µF ×3, CSS = 0.01µF, 1 A COUT = 100µF ×3, VOUT1 = 1.5V, VOUT2 = 1.5V, VIN = 12V IQ(VIN) Input Supply Bias Current VIN = 12V, VOUT = 1.5V, Burst Mode Operation 5 mA VIN = 12V, VOUT = 1.5V, Pulse-Skipping Mode 15 mA VIN = 12V, VOUT= 1.5V, Switching Continuous 65 mA Shutdown, RUN = 0, VIN = 12V 50 µA IS(VIN) Input Supply Current VIN = 5V, VOUT = 1.5V, IOUT = 13A 4.6 A VIN = 12V, VOUT = 1.5V, IOUT = 13A 1.853 A
Output Specifications
IOUT1(DC), IOUT2(DC) Output Continuous Current Range VIN = 12V, VOUT = 1.5V (Notes 7, 8) 0 13 A ΔVOUT1(LINE)/VOUT1 Line Regulation Accuracy VOUT = 1.5V, VIN from 4.75V to 16V l 0.01 0.025 %/V ΔVOUT2(LINE)/VOUT2 IOUT = 0A for Each Output, ΔVOUT1/VOUT1 Load Regulation Accuracy For Each Output, VOUT = 1.5V, 0A to 13A l 0.35 0.5 % ΔVOUT2/VOUT2 VIN = 12V (Note 7) VOUT1(AC), VOUT2(AC) Output Ripple Voltage For Each Output, IOUT = 0A, COUT = 100µF ×3/ 15 mVP-P X7R/Ceramic, 470µF POSCAP, VIN = 12V, VOUT = 1.5V, Frequency = 400kHz fS (Each Channel) Output Ripple Voltage Frequency VIN = 12V, VOUT = 1.5V, fSET = 1.25V (Note 4) 500 kHz fSYNC SYNC Capture Range 400 780 kHz (Each Channel) ΔVOUTSTART Turn-On Overshoot COUT = 100µF/X5R/Ceramic, 470µF POSCAP, 10 mV (Each Channel) VOUT = 1.5V, IOUT = 0A VIN = 12V 10 mV tSTART Turn-On Time COUT = 100µF/X5R/Ceramic, 470µF POSCAP, 5 ms (Each Channel) No Load, TRACK/SS with 0.01µF to GND, 5 ms VIN = 12V ΔVOUT(LS) Peak Deviation for Dynamic Load Load: 0% to 50% to 0% of Full Load 30 mV (Each Channel) COUT = 22µF ×3/X5R/Ceramic, 470µF POSCAP VIN = 12V, VOUT = 1.5V tSETTLE Settling Time for Dynamic Load Load: 0% to 50% to 0% of Full Load, 20 µs (Each Channel) Step VIN = 12V, COUT = 100µF, 470µF POSCAP IOUT(PK) Output Current Limit VIN = 12V, VOUT = 1.5V 20 A (Each Channel)
Control Section
VFB1, VFB2 Voltage at VFB Pins IOUT = 0A, VOUT = 1.5V l 0.592 0.600 0.606 V IFB (Note 6) –5 –20 nA VOVL Feedback Overvoltage Lockout l 0.64 0.66 0.68 V 4620afc For more information www.linear.com/LTM4620A 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Package Photo Related Parts Design Resources
