Datasheet LTM4627 (Analog Devices) - 8
Description15A DC/DC µModule Regulator
Pages / Page32 / 8 — PIN FUNCTIONS V. OUT_LCL: (L12). VOSNS : (M12). DIFF_OUT: (K12). MTP1, …
File Format / SizePDF / 583 Kb
PIN FUNCTIONS V. OUT_LCL: (L12). VOSNS : (M12). DIFF_OUT: (K12). MTP1, MTP2, MTP3, MTP4, MTP5, MTP6, MTP7, MTP8. OSNS : (J12)
PIN FUNCTIONS V OUT_LCL: (L12) VOSNS : (M12) DIFF_OUT: (K12) MTP1, MTP2, MTP3, MTP4, MTP5, MTP6, MTP7, MTP8 OSNS : (J12)
LTM4627
This pin connects to VOUT through a 1M
VOSNS : (M12)
(–) Input to the Remote Sense Amplifier. resistor, and to VFB with a 60.4k resistor. The remote sense This pin connects to the ground remote sense point. The amplifier output DIFF_OUT is connected to VOUT_LCL, and remote sense amplifier is used for VOUT ≤ 3.3V. Connect drives the 60.4k top feedback resistor in remote sensing to ground when not used. applications. When the remote sense amplifier is used,
DIFF_OUT: (K12)
Output of the Remote Sense Amplifier. DIFF_OUT effectively eliminates the 1MΩ from VOUT to This pin connects to the V V OUT_LCL pin for remote sense OUT_LCL. When the remote sense amplifier is not used, applications. Otherwise float when not used. then connect VOUT_LCL to VOUT directly.
MTP1, MTP2, MTP3, MTP4, MTP5, MTP6, MTP7, MTP8 V + OSNS : (J12)
(+) Input to the Remote Sense Amplifier.
(A12, B11, C10, C11, C12, D10, D11, D12):
Extra mount- This pin connects to the output remote sense point. The ing pads used for increased solder integrity strength. remote sense amplifier is used for VOUT ≤ 3.3V. Connect Leave floating. to ground when not used. 4627fc 8 For more information www.linear.com/LTM4627 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Package Photos Package Description Revision History Typical Application Related Parts
