Datasheet LTM4608A (Analog Devices) - 4
DescriptionLow VIN, 8A DC/DC μModule Regulator with Tracking, Margining, and Frequency Synchronization
Pages / Page28 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 714 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified internal
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified internal
LTM4608A
denotes the specifications which apply over the specified internal operating temperature range (Note 2), otherwise specifications are at TA = 25°C. VIN = 5V unless otherwise noted. See Figure 1. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Control Section
VFB Voltage at FB Pin IOUT = 0A, VOUT = 1.5V, VIN = 2.7V to 5.5V 0.590 0.596 0.602 V l 0.587 0.596 0.606 V SS Delay Internal Soft-Start Delay 90 µs IFB 0.2 µA VRUN RUN Pin On/Off Threshold RUN Rising 1.4 1.55 1.7 V RUN Falling 1.3 1.4 1.5 V TRACK Tracking Threshold (Rising) RUN = VIN 0.57 V Tracking Threshold (Falling) RUN = 0V 0.18 V Tracking Disable Threshold VIN – 0.5 V RFBHI Resistor Between VOUT and FB 9.95 10 10.05 kΩ Pins ∆VPGOOD PGOOD Range ±10 % %Margining Output Voltage Margining MGN = VIN, BSEL = 0V 4 5 6 % Percentage MGN = VIN, BSEL = VIN 9 10 11 % MGN = VIN, BSEL = Float 14 15 16 % MGN = 0V, BSEL = 0V –4 –5 –6 % MGN = 0V, BSEL = VIN –9 –10 –11 % MGN = 0V, BSEL = Float –14 –15 –16 %
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings The LTM4608AI is guaranteed over the –40°C to 125°C internal operating may cause permanent damage to the device. Exposure to any Absolute temperature range and the LTM4608AMP is tested and guaranteed over Maximum Rating condition for extended periods may affect device the full –55°C to 125°C internal operating temperature range. Note that reliability and lifetime. the maximum ambient temperature consistent with these specifications
Note 2:
The LTM4608A is tested under pulsed load conditions such that is determined by specific operating conditions in conjunction with board T layout, the rated package thermal impedance and other environmental J ≈ TA. The LTM4608AE is guaranteed to meet specifications from 0°C to 125°C internal temperature. Specifications over the –40°C to factors. 125°C internal operating temperature range are assured by design,
Note 3:
See output current derating curves for different VIN, VOUT and TA. characterization and correlation with statistical process controls. 4608afe 4 For more information www.linear.com/LTM4608A Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Order Information Typical Performance Characteristics Pin Functions Simplified Block Diagram Operation Applications Information Typical Applications Package Description Package Photo Revision History Package Description Related Parts
