LTM4606 elecTrical characTerisTicsThe l denotes the specifications which apply over the specified internaloperating temperature range, otherwise specifications are at TA = 25°C (Note 2). VIN = 12V, unless otherwise noted. Per typicalapplication (front page) configuration, RFB = 40.2k.SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSControl Section VFB Voltage at VFB Pin IOUT = 0A, VOUT = 1.5V l 0.591 0.6 0.609 V VRUN RUN Pin On/Off Threshold 1 1.5 1.9 V ITRACK/SS Soft-Start Charging Current VTRACK/SS = 0V –1 –1.5 –2 µA VFCB Forced Continuous Threshold 0.57 0.6 0.63 V IFCB Forced Continuous Pin Current VFCB = 0V –1 –2 µA tON(MIN) Minimum On Time (Note 3) 50 100 ns tOFF(MIN) Minimum Off Time (Note 3) 250 400 ns RPLLIN PLLIN Input Resistor 50 kW IDRVCC Current into DRVCC Pin VOUT = 1.5V, IOUT = 1A, DRVCC = 5V 15 25 mA RFBHI Resistor Between VOUT and VFB Pins 60.098 60.4 60.702 kW VRUN(MAX) Maximum RUN Pin Voltage 5.1V Zener Clamp 5 V Margin Section VMPGM Margin Reference Voltage 1.18 V VMARG0, VMARG1 MARG0, MARG1 Voltage Threshold 1.4 V PGOOD DVFBH PGOOD Upper Threshold VFB Rising 7 10 13 % DVFBL PGOOD Lower Threshold VFB Falling –7 –10 –13 % DVFB(HYS) PGOOD Hysteresis VFB Returning 1.5 % VPGL PGOOD Low Voltage IPGOOD = 5mA 0.15 0.4 V Note 1: Stresses beyond those listed under Absolute Maximum Ratings –40°C to 125°C internal operating temperature range. The LTM4606MP may cause permanent damage to the device. Exposure to any Absolute is guaranteed and tested over the –55°C to 125°C internal operating Maximum Rating condition for extended periods may affect device temperature range. Note that the maximum ambient temperature reliability and lifetime. consistent with these specifications is determined by specific operating Note 2: The LTM4606E is guaranteed to meet performance specifications conditions in conjunction with board layout, the rated package thermal over the 0°C to 125°C internal operating temperature range. Specifications resistance and other environmental factors. over the –40°C to 125°C internal operating temperature range are assured Note 3: 100% tested at die level only. by design, characterization and correlation with statistical process Note 4: See output current derating curves for different VIN, VOUT and TA. controls. The LTM4606I is guaranteed to meet specifications over the 4606fd 4 For more information www.linear.com/LTM4606 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Package Photograph Related Parts
