Datasheet LTM8032 (Analog Devices) - 5
Description | EN55022B Compliant 36V, 2A DC/DC µModule |
Pages / Page | 26 / 5 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 532 Kb |
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum Required Input Voltage
LTM8032
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Minimum Required Input Voltage Minimum Required Input Voltage vs Load Current, VOUT = 5V vs Load Current, VOUT = 8V Bias Current vs Output Current
7.5 11.0 30 3.3VOUT 5VOUT 10.5 25 7.0 8VOUT 10.0 20 6.5 TAGE (V) TAGE (V) 9.5 15 6.0 INPUT VOL INPUT VOL 9.0 10 BIAS CURRENT (mA) 5.5 TO RUN 8.5 TO RUN 5 TO START TO START RUN/SS ENABLED RUN/SS ENABLED 5.0 8.0 0 0 500 1000 1500 2000 0 500 1000 1500 2000 0 500 1000 1500 2000 LOAD CURRENT (mA) LOAD CURRENT (mA) OUTPUT CURRENT (mA) 8032 G10 8032 G11 8032 G12
Output Current vs Input Voltage Input Current vs Input Voltage Temperature Rise vs (Output Shorted) (Output Shorted) Load Current, VOUT = 2.5V (LGA)
3200 1200 35 3000 1000 30 2800 25 800 2600 20 2400 600 TURE RISE (°C) 15 2200 400 OUTPUT CURRENT (mA) INPUT CURRENT (mA) 10 2000 TEMPERA 5VIN 200 12VIN 1800 5 24VIN 36VIN 1600 0 0 0 10 20 30 40 0 10 20 30 40 0 500 1000 1500 2000 2500 INPUT VOLTAGE (V) INPUT VOLTAGE (V) LOAD CURRENT (mA) 8032 G13 8032 G14 8032 G15
Temperature Rise vs Temperature Rise vs Temperature Rise vs Load Current, VOUT = 3.3V (LGA) Load Current, VOUT = 5V (LGA) Load Current, VOUT = 8V (LGA)
40 40 50 35 45 35 40 30 30 35 25 25 30 20 20 25 TURE RISE (°C) TURE RISE (°C) 15 15 20 15 TEMPERA 10 5VIN TEMPERA 10 TEMPERATURE RISE (°C) 12V 10 IN 12VIN 12VIN 5 24VIN 5 24VIN 5 24VIN 36VIN 36VIN 36VIN 0 0 0 0 500 1000 1500 2000 2500 0 500 1000 1500 2000 2500 0 500 1000 1500 2000 2500 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8032 G16 8032 G17 8032 G18 8032fg For more information www.linear.com/LTM8032 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Package Photographs Related Parts
