Datasheet LTM4602 (Analog Devices) - 2
Description6A High Efficiency DC/DC µModule
Pages / Page24 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 340 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. PART MARKING*. PACKAGE DESCRIPTION
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION
LTM4602
FCB, EXTV TOP VIEW CC, PGOOD, RUN/SS, VOUT .. –0.3V to 6V CC V IN IN, SVIN, fADJ .. –0.3V to 20V OSET f ADJ SV EXTV V VOSET, COMP ... –0.3V to 2.7V COMP Operating Temperature Range (Note 2).. –40°C to 85°C VIN SGND Junction Temperature ... 125°C RUN/SS FCB Storage Temperature Range ... –55°C to 125°C PGOOD PGND VOUT LGA PACKAGE 104-LEAD (15mm × 15mm × 2.8mm) TJMAX = 125°C, θJA = 15°C/W, θJC = 6°C/W, θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS WEIGHT = 1.7g
ORDER INFORMATION LEAD FREE FINISH PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTM4602EV#PBF LTM4602V 104-Lead (15mm × 15mm × 2.8mm) LGA –40°C to 85°C LTM4602IV#PBF LTM4602V 104-Lead (15mm × 15mm × 2.8mm) LGA –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ This product is only offered in trays. For more information go to: http://www.linear.com/packaging/
The ELECTRICAL CHARACTERISTICS
denotes the specifi cations which apply over the –40°C to 85°C temperature range, otherwise specifi cations are at TA = 25°C, VIN = 12V. External CIN = 120μF, COUT = 200μF/Ceramic per typical application (front page) confi guration. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN(DC) Input DC Voltage l 4.5 20 V VOUT(DC) Output Voltage FCB = 0V VIN = 5V or 12V, VOUT = 1.5V, IOUT = 0A 1.478 1.50 1.522 V l 1.470 1.50 1.530
Input Specifi cations
VIN(UVLO) Under Voltage Lockout Threshold IOUT = 0A 3.4 4 V IINRUSH(VIN) Input Inrush Current at Startup IOUT = 0A. VOUT = 1.5V, FCB = 0 VIN = 5V 0.6 A VIN = 12V 0.7 A IQ(VIN) Input Supply Bias Current IOUT = 0A, EXTVCC Open VIN = 12V, VOUT = 1.5V, FCB = 5V 1.2 mA VIN = 12V, VOUT = 1.5V, FCB = 0V 42 mA VIN = 5V, VOUT = 1.5V, FCB = 5V 1.0 mA VIN = 5V, VOUT = 1.5V, FCB = 0V 52 mA Shutdown, RUN = 0.8V, VIN = 12V 50 100 μA 4602fa 2
