Datasheet LTM4601HV (Analog Devices) - 8
Description12A 28VIN DC/DC µModule Regulator with PLL, Output Tracking and Margining
Pages / Page30 / 8 — PIN FUNCTIONS (See Package Description for Pin Assignment) SGND (Pin …
File Format / SizePDF / 528 Kb
PIN FUNCTIONS (See Package Description for Pin Assignment) SGND (Pin H12):. RUN (Pin A10):. COMP (Pin A11):. PGOOD (Pin G12):
PIN FUNCTIONS (See Package Description for Pin Assignment) SGND (Pin H12): RUN (Pin A10): COMP (Pin A11): PGOOD (Pin G12):
LTM4601HV
Signal Ground. This pin connects to
RUN (Pin A10):
Run Control Pin. A voltage above 1.9V PGND at output capacitor point. See Figure 17. will turn on the module, and when below 1V, will turn
COMP (Pin A11):
Current Control Threshold and Error off the module. A programmable UVLO function can be Amplifier Compensation Point. The current comparator accomplished by connecting to a resistor divider from threshold increases with this control voltage. The voltage VIN to ground. See Figure 1. This pin has a 5.1V Zener to ranges from 0V to 2.4V with 0.7V corresponding to zero ground. Maximum pin voltage is 5V. Limit current into the sense voltage (zero current). RUN pin to less than 1mA.
PGOOD (Pin G12):
Output Voltage Power Good Indicator.
VOUT_LCL (Pin L12):
VOUT connects directly to this pin to Open-drain logic output that is pulled to ground when the bypass the remote sense amplifier, or DIFFVOUT connects output voltage is not within ±10% of the regulation point, to this pin when remote sense amplifier is used. after a 25µs power bad mask timer expires. 4601hvfb 8 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Package Photos Related Parts
