LTM4600HV absoluTe MaxiMuM raTingspin conFiguraTion(Note 1) FCB, EXTV TOP VIEW CC, PGOOD, RUN/SS, VOUT ... –0.3V to 6V V CC V IN IN, SVIN, fADJ .. –0.3V to 28V EXT V OSET f ADJ SV VOSET, COMP .. –0.3V to 2.7V COMP Operating Temperature Range (Note 2) VIN SGND E and I Grades ...–40°C to 85°C RUN/SS FCB MP Grade ... –55°C to 125°C PGOOD Junction Temperature ... 125°C PGND Storage Temperature Range .. –55°C to 125°C Peak Solder Reflow Body Temperature ... 245°C VOUT LGA PACKAGE 104-LEAD (15mm × 15mm × 2.82mm) TJMAX = 125°C, θJA = 15°C/W, θJC = 6°C/W, θJA DERIVED FROM 95mm × 76mm PCB WITH 4 LAYERS, WEIGHT = 1.7g orDer inForMaTionPART MARKINGPACKAGEMSLTEMPERATURE RANGEPART NUMBERPAD OR BALL FINISHDEVICEFINISH CODETYPERATING(SEE NOTE 2) LTM4600HVEV#PBF LTM4600HVEV –40°C to 85°C LTM4600HVIV#PBF Au (RoHS) LTM4600HVIV e4 LGA 3 –40°C to 85°C LTM4600HVMPV#PBF LTM4600HVMPV –55°C to 125°C • Consult Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Pad or ball finish code is per IPC/JEDEC J-STD-609. Procedures: www.linear.com/umodule/pcbassembly • Terminal Finish Part Marking: www.linear.com/leadfree • LGA and BGA Package and Tray Drawings: www.linear.com/packaging 4600hvfe 2 For more information www.linear.com/LTM4600HV Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Decoupling Requirements Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
