Datasheet LT4356MP-1, LT4356MP-2 (Analog Devices) - 4
DescriptionSurge Stopper
Pages / Page24 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 511 Kb
LT4356MP-1/LT4356MP-2
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VCC = 12V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IOUT OUT Pin Input Current VOUT = VCC = 12V l 200 300 µA VOUT = VCC = 12V, VSHDN = 0V l 6 14 mA ΔVOUT OUT Pin High Threshold ΔVOUT = VCC – VOUT; EN from Low to High l 0.25 0.5 0.7 V VSHDN SHDN Pin Threshold VCC = 12V to 48V 0.6 1.4 1.7 V l 0.4 2.1 V VSHDN(FLT) SHDN Pin Float Voltage VCC = 12V to 48V l 0.6 1.2 2.1 V ISHDN SHDN Pin Current VSHDN = 0V l –1 –4 –8 µA tOFF(OC) Overcurrent Turn-Off Delay Time GATE from High to Low, ΔVSNS = 0 → 120mV l 2 4 µs tOFF(OV) Overvoltage Turn-Off Delay Time GATE from High to Low, VFB = 0 → 1.5V l 0.25 1 µs
Note 1:
Note 2:
All currents into device pins are positive; all currents out of device may cause permanent damage to the device. Exposure to any Absolute pins are negative. All voltages are referenced to GND unless otherwise Maximum Rating condition for extended periods may affect device specified. reliability and lifetime.
Note 3:
An internal clamp limits the GATE pin to a minimum of 10V above the OUT pin. Driving this pin to voltages beyond the clamp may damage the device.
TYPICAL PERFORMANCE CHARACTERISTICS Specifications are at VCC = 12V, TA = 25°C unless otherwise noted. ICC vs VCC ICC (Shutdown) vs VCC ICC (Shutdown) vs VCC
1000 60 120 LT4356-1 LT4356-2 IN+ = 1.3V 50 100 800 40 80 600 (µA) (µA) 30 (µA) 60 I CC I CC I CC 400 20 40 200 10 20 0 0 0 0 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 80 0 10 20 30 40 50 60 70 80 VCC (V) VCC (V) VCC (V) 4356mp12 G01 4356mp12 G02 4356mp12 G03 4356mp12fc 4 For more information www.linear.com/LT4356MP-1
