Datasheet LTC4015 (Analog Devices) - 3
DescriptionMultichemistry Buck Battery Charger Controller with Digital Telemetry System
Pages / Page76 / 3 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 5). ORDER …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 5). ORDER INFORMATION http://www.linear.com/product/LTC4015#orderinfo
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 5) ORDER INFORMATION http://www.linear.com/product/LTC4015#orderinfo
LTC4015
TOP VIEW VIN, CSN ... –0.3V to 40V BOOST to SW.. –0.3 to 5.5V CELLS0 CHEM1 CHEM0 V IN INFET CLP CLN BATSENS to CSN, CSP to CSN, CLP to CLN, CLP, CLN 38 37 36 35 34 33 32 to SYS ..±0.3V CELLS1 1 31 SYS DVCC, DRVCC ... –0.3V to 5.5V CELLS2 2 30 SYSM5 CELLSO, CELLS1, CELLS2, CHEM0, CHEM1, DVCC 3 29 OUTFET MPPT, EQ ..–0.3V to INTV SCL 4 28 INTV CC CC SDA 5 27 DRV SDA, SCL, SMBALERT .. –0.3V to DV CC CC SMBALERT 6 I 39 26 BG UVCLFB (Note 4) ..±200µA SGND 7 GND 25 BOOST INTVCC Peak Output Current ..100mA UVCLFB 8 24 TG Operating Junction Temperature Range VC 9 23 SW (Notes 2,3) ... –40 to 125°C RT 10 22 2P5VCC Storage Temperature Range ..–65 to 150°C NTC 11 21 MPPT NTCBIAS 12 20 CSP 13 14 15 16 17 18 19 EQ GND CSN CSPM5 CCREFM CCREFP BATSENS UHF PACKAGE 38-LEAD (5mm × 7mm) PLASTIC QFN TJMAX = 125°C, θJA = 34°C/W (NOTE 1) EXPOSED PAD (PIN 39) IS GND, MUST BE SOLDERED TO PCB GND
ORDER INFORMATION http://www.linear.com/product/LTC4015#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC4015EUHF#PBF LTC4015EUHF#TRPBF 4015 38-Lead (5mm × 7mm) Plastic QFN –40°C to 125°C LTC4015IUHF#PBF LTC4015IUHF#TRPBF 4015 38-Lead (5mm × 7mm) Plastic QFN –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
DATA SHEET CONVENTIONS
• VPINNAME and IPINNAME represents the voltage on a pin • LiFePO4 is lithium iron phosphate, Li-Ion is used for or the pin current; VEQ = EQ Pin Voltage. both lithium-ion and lithium-ion polymer • Hexadecimal numbers are prefixed with 0x; 0x10 is a • Lithium chemistries refers to LiFePO4 , lithium-ion, and hexadecimal 10 lithium-ion polymer as a group. • Register symbol names will be capitalized. Symbols • When a register name is used in square brackets, this within a register will be lower case; means the 16 bit value associated with that register; en_meas_sys_valid_alert is bit 15 in register For example [VBAT] is the 16 bit ADC measurement EN_LIMIT_ALERTS (0x0D) value of the per cell battery voltage. 4015fb For more information www.linear.com/LTC4015 3 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Data Sheet Conventions Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram I2C Timing Diagram Operation Applications Information Register Description DETAILED Register Descriptions Typical Applications Package Description Revision History Typical Application Related Parts
