Datasheet LT3652 (Analog Devices) - 2
DescriptionPower Tracking 2A Battery Charger for Solar Power
Pages / Page26 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 534 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3652
Voltages: BAT-SENSE ... –0.5V to +0.5V VIN ..40V NTC, TIMER, ..2.5V VIN_REG, SHDN, CHRG, FAULT .. VIN + 0.5V, 40V VFB ..5V SW ..40V Operating Junction Temperature Range SW-VIN...4.5V (Note 2) ... –40°C to 125°C BOOST ...SW+10V, 50V Storage Temperature Range ... –65°C to 150°C BAT, SENSE ...15V
PIN CONFIGURATION
TOP VIEW TOP VIEW V 1 IN 12 SW V 2 11 BOOST V 1 12 SW IN_REG IN V 2 11 BOOST SHDN 3 13 10 SENSE IN_REG SHDN 3 13 10 SENSE CHRG 4 GND 9 BAT CHRG 4 GND 9 BAT FAULT 5 8 NTC FAULT 5 8 NTC TIMER 6 7 V TIMER 6 7 V FB FB DD PACKAGE MSE PACKAGE 12-LEAD (3mm × 3mm) PLASTIC DFN 12-LEAD PLASTIC MSOP TJMAX = 125°C, θJA = 43°C/W, θJC = 3°C/W TJMAX = 125°C, θJA = 43°C/W, θJC = 3°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB
LT3652EDD#PBF LT3652EDD#TRPBF LFHT 12-Lead Plastic DFN 3mm × 3mm –40°C to 125°C LT3652IDD#PBF LT3652IDD#TRPBF LFHT 12-Lead Plastic DFN 3mm × 3mm –40°C to 125°C LT3652EMSE#PBF LT3652EMSE#TRPBF 3652 12-Lead Plastic MSOP –40°C to 125°C LT3652IMSE#PBF LT3652IMSE#TRPBF 3652 12-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 3652fe 2 For more information www.linear.com/LT3652 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Typical Application Related Parts
