Datasheet LTC4012, LTC4012-1, LTC4012-2 (Analog Devices) - 5
DescriptionHigh Efficiency, Multi-Chemistry Battery Charger with PowerPath Control
Pages / Page28 / 5 — Note 1:. Note 3:. Note 2:. Note 4:. Note 5:
File Format / SizePDF / 395 Kb
Note 1: Note 3: Note 2: Note 4: Note 5:
LTC4012/ LTC4012-1/LTC4012-2 electrical characteristics
Note 1:
Note 3:
Operating junction temperature TJ (in °C) is calculated from may cause permanent damage to the device. Exposure to any Absolute the ambient temperature TA and the total continuous package power Maximum Rating condition for extended periods may affect device dissipation PD (in watts) by the formula TJ = TA + (θJA • PD). Refer to the reliability and lifetime. Applications Information section for details.
Note 2:
The LTC4012C is guaranteed to meet performance specifications
Note 4:
All currents into device pins are positive; all currents out of device over the 0°C to 85°C operating temperature range. The LTC4012I is pins are negative. All voltages are referenced to GND, unless otherwise guaranteed to meet performance specifications over the –40°C to 125°C specified. operating temperature range.
Note 5:
Output current may be limited by internal power dissipation. Refer to the Applications Information section for details. test circuits LTC4012 FROM ICL (CLP = CLN) – – – EA 1.2085V + PROG VFB ITH 13 9 12 1.2085V + TARGET LTC1055 – 0.6V 40012 TC01 LTC4012-1 LTC4012-2 FROM ICL (CLP = CLN) – – – EA 1.2085V + PROG BAT ITH 13 11 12 TARGET VARIES + WITH FVSO,1 LTC1055 – 0.6V 40012 TC02 4012fa Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Test Circuits Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
