LTC4101 ELECTRICAL CHARACTERISTICSThe l denotes the specifi cations which apply over the full operatingtemperature range, otherwise specifi cations are at TA = 25°C. VDCIN = 20V, VDD = 3.3V, VBAT = 4V unless otherwise noted. (Note 4)SYMBOL PARAMETERCONDITIONSMINTYPMAXUNITSCurrent Sense Amplifi er, CA1 Input Bias Current into BAT Pin 11.66 μA CMSL CA1/I1 Input Common Mode Low l 0 V CMSH CA1/I1 Input Common Mode High VDCIN ≤ 28V l VCLN–0.2 V Current Comparators IREV ITREV Reverse Current Threshold (VCSP-VBAT) –30 mV Current Sense Amplifi er, CA2 Transconductance 1 mmho Source Current Measured at ITH, VITH = 1.4V –40 μA Sink Current Measured at ITH, VITH = 1.4V 40 μA Current Limit Amplifi er Transconductance 1.5 mmho VCLP Current Limit Threshold l 93 100 107 mV ICLN CLN Input Bias Current 50 nA Voltage Error Amplifi er, EA Transconductance 1 mmho Sink Current Measured at ITH, VITH = 1.4V 36 μA OVSD Overvoltage Shutdown Threshold as a Percent l 102 107 110 % of Programmed Charger Voltage Input P-Channel FET Driver (INFET) DCIN Detection Threshold (VDCIN-VCLP) DCIN Voltage Ramping Up l 0 0.17 0.25 V from VCLP-0.05V Forward Regulation Voltage (VDCIN-VCLP) l 25 50 mV Reverse Voltage Turn-Off Voltage (VDCIN-VCLP) l –60 –25 mV INFET ON Clamping Voltage (VDCIN-VINFET) IINFET = 1μA l 5 5.8 6.5 V INFET OFF Clamping Voltage (VDCIN-VINFET) IINFET = –25μA 0.25 V Oscillator fOSC Regulator Switching Frequency 255 300 345 kHz fMIN Regulator Switching Frequency in Drop Out Duty Cycle ≥ 98% 20 25 kHz DCMAX Regulator Maximum Duty Cycle VCSP = VBAT 98 99 % Gate Drivers (TGATE, BGATE) VTGATE High (VCLP-VTGATE) ITGATE = –1mA 50 mV VBGATE High CLOAD = 3000pF 4.5 5.6 10 V VTGATE Low (VCLP-VTGATE) CLOAD = 3000pF 4.5 5.6 10 V VBGATE Low IBGATE = 1mA 50 mV TGATE Transition Time TGTR TGATE Rise Time CLOAD = 3000pF, 10% to 90% 50 110 ns TGTF TGATE Fall Time CLOAD = 3000pF, 10% to 90% 50 100 ns BGATE Transition Time BGTR BGATE Rise Time CLOAD = 3000pF, 10% to 90% 40 90 ns BGTF BGATE Fall Time CLOAD = 3000pF, 10% to 90% 40 80 ns VTGATE at Shutdown (VCLN-VTGATE) ITGATE = –1μA 100 mV 4101fa 3
