Datasheet LTC4006 (Analog Devices) - 4
Description4A, High Efficiency, Standalone Li-Ion Battery Charger
Pages / Page20 / 4 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 273 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC4006
denotes specifications which apply over the full operating temperature range (Note 4), otherwise specifications are at TA = 25
C. VDCIN = 20V, VBAT = 12V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Oscillator
fOSC Regulator Switching Frequency 255 300 345 kHz fMIN Regulator Switching Frequency in Drop Out Duty Cycle ≥ 98% 20 25 kHz DCMAX Regulator Maximum Duty Cycle VCSP = VBAT 98 99 %
Gate Drivers (TGATE, BGATE)
VTGATE High (VCLN – VTGATE) ITGATE = –1mA 50 mV VBGATE High CLOAD = 3000pF 4.5 5.6 10 V VTGATE Low (VCLN – VTGATE) CLOAD = 3000pF 4.5 5.6 10 V VBGATE Low IBGATE = 1mA 50 mV TGATE Transition Time TGTR TGATE Rise Time CLOAD = 3000pF, 10% to 90% 50 110 ns TGTF TGATE Fall Time CLOAD = 3000pF, 10% to 90% 50 100 ns BGATE Transition Time BGTR BGATE Rise Time CLOAD = 3000pF, 10% to 90% 40 90 ns BGTF BGATE Fall Time CLOAD = 3000pF, 10% to 90% 40 80 ns VTGATE at Shutdown (VCLN – VTGATE) ITGATE = –1µA, DCIN = 0V, CLN = 12V 100 mV VBGATE at Shutdown IBGATE = 1µA, DCIN = 0V, CLN = 12V 100 mV
Note 1:
Note 3:
Does not include tolerance of current sense resistor. may cause permanent damage to the device. Exposure to any Absolute
Note 4:
The LTC4006E is guaranteed to meet performance specifications Maximum Rating condition for extended periods may affect device from 0°C to 70°C. Specifications over the –40°C to 85°C operating reliability and lifetime. temperature range are assured by design, characterization and correlation
Note 2:
See Test Circuit with statistical process controls.
W U TYPICAL PERFOR A CE CHARACTERISTICS INFET Response Time to Reverse Current VOUT vs IOUT PWM Frequency vs Duty Cycle
0 350 Vgs OF PFET (2V/DIV) V –0.5 gs = 0 300 –1.0 250 –1.5 –2.0 Vs OF PFET (5V/DIV) 200 –2.5 150 –3.0 PROGRAMMED CURRENT = 10% –3.5 100 Vs = 0V PWM FREQUENCY (kHz) –4.0 I OUTPUT VOLTAGE ERROR (%) d (REVERSE) OF DCIN = 15V 50 PFET (5A/DIV) –4.5 DCIN = 20V DCIN = 20V VBAT = 12.6V DCIN = 24V Id = 0A 0 –5.0 1.25µs/DIV 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 TEST PERFORMED ON DEMOBOARD OUTPUT CURRENT (A) DUTY CYCLE (VOUT/VIN) VIN = 15VDC LTC4006-2 4006 G02 4006 G03 CHARGER = ON INFET = 1/2 Si4925DY ICHARGE = <10mA 4006 G01 4006fa 4
