Datasheet SRS (4000) (Songle Relay)
ManufacturerSongle Relay
DescriptionSubminature High Power Relay 1A/3A
Pages / Page2 / 1 — SRS. Series. SUBMINATURE. HIGH. POWER. RELAY. 1A/3A. C. US. 15.8M. AX. …
File Format / SizePDF / 3.8 Mb
SRS. Series. SUBMINATURE. HIGH. POWER. RELAY. 1A/3A. C. US. 15.8M. AX. AX. Features. E167996. 10.8M. ·Miniature. volume,. PCB. usage. X. A. M. ·Contact. rating:. 1A/3A
Datasheet SRS (4000) Songle Relay
SRS Series SUBMINATURE HIGH POWER RELAY 1A/3A C US 15.8M AX AX Features E167996 10.8M ·Miniature volume, PCB usage X A M ·Contact rating: 1A/3A .4 2 1 ·Temperature range: +85℃/+105℃ R50056114 Ordering Information Contact Rating SRS-12VDC-S L Contact a rrangment A / B / C Contact resistance 100mΩ(1A 6VDC) Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact rating 1A/120VAC 1A/250VAC 3 L0.36W / D0.45W A/250VAC Coil Power Max switching voltage 250VAC S sealed / F dustproof Construction Max switching current 3A 3V /5V / 6V 9V / 12V / 24V Max switching power 750VA Coil Voltage Electrical endurance 5 4 (frequency: 1800 ops/h) 1x10 ops / 1x10 ops Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B / F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ (500VDC) W VDC mA voltage voltage allowable Dielectric Between contacts 500VAC 1 minute 03 120 25 Strength and coil Leakage current Between open 05 71 70 500VAC 1 minute 1mA contacts 06 60 100 Operate time(Under nominal voltage) ≤10ms 0.36W 09 40 225 75%Max 5%Min 130% Release time(Under nominal voltage) ≤10ms ( L ) 12 30 400 Humidity 85% RH(20℃) 24 15 1600 Ambient Temperature -40℃~+85℃ 03 150 20 Functional 98m/s
²
Shock 05 89 56 resistance Destructive 980m/s
²
06 75 80 Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) 0.45W 09 50 180 75%Max 5%Min 130% Approx 4g Weight ( D ) 12 37.5 320 Sealed 24 18.7 1280 Construction Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
