SRC Series DOUBLE GROUP CONVERSION RELAY 1A C US 20.6MAX AX Features 10.2M E167996 ·Miniature volume, PCB usage X A M ·Double group individual load:1A .5 1 1 ·Temperature range:-25℃/+55℃ Ordering Information Contact Rating SRC-12VDC-S L Contact a rrangment A/C Contact resistance 50mΩ (1A 6VDC) Contact material Silver alloy:AgCdO、AgSnO2、AgNi H0.2W/L0.36W Contact rating 1A/125VAC Coil Power Max switching voltage 125VAC S sealed / F dustproof Construction Max switching current 1A 5V / 6V / 9V / 12V 18V / 24V Max switching power 125VA Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4 ops Part number endurance Mechanical 1x10 o 7 ps (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system A / B Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 50MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable nim Dielectric Between contacts 500VAC 1 minute 03 66 45 Strength and coil Leakage current Between open 500VAC 1 minute 05 41 120 1mA contacts 06 33 180 Operate time(Under nominal voltage) ≤10ms 0.20W 09 22.5 400 75%Max 10%Min 110% Release time(Under nominal voltage) ≤10ms ( H ) 12 17 700 Humidity 85% RH(20℃) 24 8.5 2800 - Ambient Temperature 25℃~+55℃ 03 120 25 Functional 98m/s ² Shock 05 71 70 resistance Destructive 980m/s ² 06 60 100 Vibration resistance 10Hz ~ 55Hz 1 . 5mm ( Double amplitude) 0.36W 09 40 220 75%Max 10%Min 110% Approx 9g Weight ( L ) 12 30 400 Construction Sealed 24 15 1600 Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
