Datasheet ADE7854, ADE7858, ADE7868, ADE7878 (Analog Devices) - 9
DescriptionPolyphase Multifunction Energy Metering IC with Harmonic and Fundamental Information
Pages / Page100 / 9 — Data Sheet. ADE7854/ADE7858/ADE7868/ADE7878. SPECIFICATIONS. Table 2. …
RevisionH
Data Sheet. ADE7854/ADE7858/ADE7868/ADE7878. SPECIFICATIONS. Table 2. Parameter1, 2. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet ADE7854/ADE7858/ADE7868/ADE7878 SPECIFICATIONS Table 2 Parameter1, 2 Min Typ Max Unit Test Conditions/Comments
link to page 11 link to page 11
VDD = 3.3 V ± 10%, AGND = DGND = 0 V, on-chip reference, CLKIN = 16.384 MHz, TMIN to TMAX = −40°C to +85°C, TTYP= 25°C.
Table 2. Parameter1, 2 Min Typ Max Unit Test Conditions/Comments
ACCURACY Active Energy Measurement Active Energy Measurement Error (per Phase) Total Active Energy 0.1 % Over a dynamic range of 1000 to 1, PGA = 1, 2, 4; integrator off 0.2 % Over a dynamic range of 3000 to 1, PGA = 1, 2, 4; integrator off 0.1 % Over a dynamic range of 500 to 1, PGA = 8, 16; integrator on Fundamental Active Energy 0.1 % Over a dynamic range of 1000 to 1, PGA = 1, 2, 4; (ADE7878 Only) integrator off 0.2 % Over a dynamic range of 3000 to 1, PGA = 1, 2, 4; integrator off 0.1 % Over a dynamic range of 500 to 1, PGA = 8, 16; integrator on AC Power Supply Rejection VDD = 3.3 V + 120 mV rms/120 Hz/100 Hz, IPx = Output Frequency Variation 0.01 % VPx = ±100 mV rms DC Power Supply Rejection VDD = 3.3 V ± 330 mV dc; IPx = VPx = ±100 mV rms Output Frequency Variation 0.01 % Total Active Energy Measurement 2 kHz Bandwidth REACTIVE ENERGY MEASUREMENT (ADE7858, ADE7868, AND ADE7878) Reactive Energy Measurement Error (per Phase) Total Reactive Energy 0.1 % Over a dynamic range of 1000 to 1, PGA = 1, 2, 4; integrator off 0.2 % Over a dynamic range of 3000 to 1, PGA = 1, 2, 4; integrator off 0.1 % Over a dynamic range of 500 to 1, PGA = 8, 16; integrator on Fundamental Reactive Energy 0.1 % Over a dynamic range of 1000 to 1, PGA = 1, 2, 4; (ADE7878 Only) integrator off 0.2 % Over a dynamic range of 3000 to 1, PGA = 1, 2, 4; integrator off 0.1 % Over a dynamic range of 500 to 1, PGA = 8, 16; integrator on AC Power Supply Rejection VDD = 3.3 V + 120 mV rms/120 Hz/100 Hz, IPx = Output Frequency Variation 0.01 % VPx = ±100 mV rms DC Power Supply Rejection VDD = 3.3 V ± 330 mV dc; IPx = VPx = ±100 mV rms Output Frequency Variation 0.01 % Total Reactive Energy Measurement 2 kHz Bandwidth RMS MEASUREMENTS I rms and V rms Measurement 2 kHz Bandwidth I rms and V rms Measurement Error 0.1 % Over a dynamic range of 1000 to 1, PGA = 1 (PSM0 Mode) Rev. H | Page 9 of 100 Document Outline Features Applications General Description Table of Contents Revision History Functional Block Diagrams Specifications Timing Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuit Terminology Power Management PSM0—Normal Power Mode (All Parts) PSM1—Reduced Power Mode (ADE7868, ADE7878 Only) PSM2—Low Power Mode (ADE7868, ADE7878 Only) PSM3—Sleep Mode (All Parts) Power-Up Procedure Hardcore Reset Software Reset Functionality Theory of Operation Analog Inputs Analog-to-Digital Conversion Antialiasing Filter ADC Transfer Function Current Channel ADC Current Waveform Gain Registers Current Channel HPF Current Channel Sampling di/dt Current Sensor and Digital Integrator Voltage Channel ADC Voltage Waveform Gain Registers Voltage Channel HPF Voltage Channel Sampling Changing Phase Voltage Datapath POWER QUALITY MEASUREMENTS Zero-Crossing Detection Zero-Crossing Timeout Phase Sequence Detection Time Interval Between Phases Period Measurement Phase Voltage Sag Detection SAG Level Set Peak Detection Overvoltage and Overcurrent Detection Overvoltage and Overcurrent Level Set Neutral Current Mismatch—ADE7868, ADE7878 Phase Compensation Reference Circuit Digital Signal Processor Root Mean Square Measurement Current RMS Calculation Current RMS Offset Compensation Current Mean Absolute Value Calculation—ADE7868 and ADE7878 Only Current MAV Gain and Offset Compensation Voltage Channel RMS Calculation Voltage RMS Offset Compensation Active Power Calculation Total Active Power Calculation Fundamental Active Power Calculation—ADE7878 Only Active Power Gain Calibration Active Power Offset Calibration Sign of Active Power Calculation Active Energy Calculation Integration Time Under Steady Load Energy Accumulation Modes Line Cycle Active Energy Accumulation Mode Reactive Power Calculation—ADE7858, ADE7868, ADE7878 Only Reactive Power Gain Calibration Reactive Power Offset Calibration Sign of Reactive Power Calculation Reactive Energy Calculation Integration Time Under A Steady Load Energy Accumulation Modes Line Cycle Reactive Energy Accumulation Mode Apparent Power Calculation Apparent Power Gain Calibration Apparent Power Offset Calibration Apparent Power Calculation Using VNOM Apparent Energy Calculation Integration Time Under Steady Load Energy Accumulation Mode Line Cycle Apparent Energy Accumulation Mode Waveform Sampling Mode Energy-to-Frequency Conversion Synchronizing Energy Registers with CFx Outputs CF Outputs for Various Accumulation Modes Sign of Sum-of-Phase Powers in the CFx Datapath No Load Condition No Load Detection Based On Total Active, Reactive Powers No Load Detection Based on Fundamental Active and Reactive Powers—ADE7878 Only No Load Detection Based on Apparent Power Checksum Register Interrupts Using the Interrupts with an MCU Serial Interfaces Serial Interface Choice I2C-Compatible Interface I2C Write Operation I2C Read Operation SPI-Compatible Interface SPI Read Operation SPI Write Operation HSDC Interface Quick Setup as Energy Meter Layout Guidelines Crystal Circuit ADE7878 Evaluation Board Die Version Silicon Anomaly ADE7854/ADE7858/ADE7868/ADE7878 Functionality Issues Functionality Issues SECTION 1. ADE7854/ADE7858/ADE7868/ADE7878 Functionality Issues Registers List Outline Dimensions Ordering Guide
