Datasheet LT581X (Analog Devices)
Description200°C Voltage Reference
Pages / Page1 / 1 — FEATURES. Pin conFigURATion. oRdER inFoRmATion ORDER PART NUMBER. PART …
File Format / SizePDF / 78 Kb
FEATURES. Pin conFigURATion. oRdER inFoRmATion ORDER PART NUMBER. PART MARKING. PACKAGE DESCRIPTION. TEMPERATURE RANGE
Datasheet LT581X Analog Devices
LT581X 200°C Voltage Reference
FEATURES Pin conFigURATion
n 100% Tested at 200°C BOTTOM VIEW n Absolute Maximum Operating Temperature: 225°C INPUT n Guaranteed Temperature Coefficient 1 2 OUTPUT 3 GND H PACKAGE 3-LEAD TO-39 METAL CAN TJMAX = 225°C, θJA = 150°C/W L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
oRdER inFoRmATion ORDER PART NUMBER PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT581XH LT581UH 3-Lead TO-39 Metal Can –55°C to 200°C These parts are only available in SnPb finish. This product is only offered in trays. For more information go to: http://www.linear.com/packaging/
ElEcTRicAl chARAcTERiSTicS VIN = 15V, (Note 1) MIN/MAX TYP TYP MIN/MAX SYMBOL PARAMETER CONDITIONS 25°C 150°C 175°C 200°C UNITS
VR Output Voltage Min 9.970 V Max 10.030 10.020 10.032 9.900 10.100 V TC Temperature Coefficient –55°C ≤ TA ≤ 125°C 10 ppm/°C 125°C to 150°C 25 ppm/°C 150°C to 175°C 90 ppm/°C 125°C to 200°C 150* ppm/°C ∆VOUT Line Regulation 15V ≤ VIN ≤ 30V 3 8 15 60 mV ∆V 13V ≤ V 1 2 5 10 mV IN IN ≤ 15V ∆VOUT Load Regulation (Sourcing) 0mA ≤ IOUT ≤ 5mA 0.5 0.8 10 60* mV/mA ∆IOUT IQ Quiescent Current 1.0 1.5 1.8 2.5 mA *Not tested
Note 1:
Devices are 100% tested at 200°C ±3° to the limits shown. Since parameters change rapidly with temperature, devices are guaranteed at 190°C ±3°C and QA testing is done at 190°C ±3°. For normal operating temperature range specifications please see the LT581 data sheet. Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the interconnection of its circuits as described herein will not infringe on existing patent rights. 581xfa Linear Technology Corporation LT 0113 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/581X LINEAR TECHNOLOGY CORPORATION 2008 Document Outline Features Pin Configuration Order Information Electrical Characteristics
