Datasheet ADR512 (Analog Devices) - 10
Description | 1.2 V Precision Low Noise Shunt Voltage Reference |
Pages / Page | 12 / 10 — ADR512. Data Sheet. OUTLINE DIMENSIONS. 3.04 2.90 2.80. 1.40 1.30 1.20. … |
Revision | A |
File Format / Size | PDF / 282 Kb |
ADR512. Data Sheet. OUTLINE DIMENSIONS. 3.04 2.90 2.80. 1.40 1.30 1.20. 2.64 2.10. 0.60. 1.03. 0.45. 0.89. 2.05 1.78. 1.02. 0.54. 0.95. REF. 1.12
ADR512 Data Sheet OUTLINE DIMENSIONS 3.04 2.90 2.80 1.40 1.30 1.20 3 2.64 2.10 1 2 0.60 1.03 0.45 0.89 2.05 1.78 1.02 0.54 0.95 REF 1.12 GAUGE 0.88 PLANE 0.89 0.100 0.180 0.013 0.085 0.51 SEATING 0.25 PLANE 0.37 0.60 MAX 0.30 MIN C COMPLIANT TO JEDEC STANDARDS TO-236-AB 011909-
Figure 15. 3-Lead Small Outline Transistor Package [SOT-23] (RT-3) Dimensions shown in millimeters
ORDERING GUIDE Initial Accuracy Temperature Number Output Voltage Coefficient Package Package of Parts Temperature Model (VO) (mV) (%) (ppm/°C) Description Option Branding per Reel Range
ADR512ARTZ-REEL7 1.2 3.5 0.3 60 3-Lead SOT-23 RT-3 R1R 3,000 −40°C to +85°C Rev. A | Page 10 of 12 Document Outline Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Parameter Definitions Temperature Coefficient Thermal Hysteresis Applications Section Adjustable Precision Voltage Source Output Voltage Trim Using the ADR512 with Precision Data Converters Precise Negative Voltage Reference Outline Dimensions Ordering Guide
