Datasheet LT1389 (Analog Devices) - 4
DescriptionNanopower Precision Shunt Voltage Reference
Pages / Page12 / 4 — 5V ELECTRICAL CHARACTERISTICS The. denotes specifications which apply …
File Format / SizePDF / 219 Kb
5V ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
5V ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LT1389
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. (Note 3) PARAMETER CONDITIONS MIN TYP MAX UNITS
Reverse Breakdown Voltage LT1389BCS8 (IR = 1.5µA) 4.99625 5.000 5.00375 V – 0.075 0.075 % LT1389BCS8 (IR = 1.5µA) ● 4.979 5.000 5.021 V – 0.42 0.42 % Reverse Breakdown Change 1.5µA ≤ IR ≤ 200µA 0.2 1.5 mV with Current (Note 4) ● 0.2 3 mV 200µA ≤ IR ≤ 2mA 0.3 4 mV ● 0.3 6 mV Minimum Operating Current ● 1 µA Temperature Coefficient IR = 1.5µA ● 12 50 ppm/°C Reverse Dynamic Impedance (Note 5) 1.5µA ≤ IR ≤ 2mA 0.75 2 Ω ● 0.75 3 Ω Low Frequency Noise (Note 6) IR = 1.5µA, 0.1Hz ≤ f ≤ 10Hz 100 µVP-P
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
Output requires 0.1µF for operating current greater than 1mA. of a device may be impaired.
Note 5:
This parameter is guaranteed by “reverse breakdown change with
Note 2:
If the part is stored outside of the specific operating temperature current” test. range, the output may shift due to hysteresis.
Note 6:
Peak-to-peak noise is measured with a single highpass filter at
Note 3:
ESD (Electrostatic Discharge) sensitive device. Use proper ESD 0.1Hz and 2-pole lowpass filter at 10Hz. handling precautions. 4
