Datasheet LTC2057, LTC2057HV (Analog Devices) - 5
DescriptionHigh Voltage, Low Noise Zero-Drift Operational Amplifier
Pages / Page32 / 5 — elecTrical characTerisTics (LTC2057/LTC2057HV) The. denotes the …
elecTrical characTerisTics (LTC2057/LTC2057HV) The. denotes the specifications which apply
elecTrical characTerisTics (LTC2057/LTC2057HV) The denotes the specifications which apply
LTC2057/LTC2057HV
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. Unless otherwise noted, VS = ±15V; VCM = VOUT = 0V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 3) 0.5 4.5 μV ∆VOS/∆T Average Input Offset Voltage Drift (Note 3) –40°C to 125°C l 0.015 μV/°C IB Input Bias Current (Note 4) 30 200 pA –40°C to 85°C l 360 pA –40°C to 125°C l 6.0 nA IOS Input Offset Current (Note 4) 60 400 pA –40°C to 85°C l 480 pA –40°C to 125°C l 1.5 nA in Input Noise Current Spectral Density 1kHz 150 fA/√Hz en Input Noise Voltage Spectral Density 1kHz 12 nV/√Hz en P-P Input Noise Voltage DC to 10Hz 210 nVP-P CIN Differential Input Capacitance 3 pF Common Mode Input Capacitance 3 pF CMRR Common Mode Rejection Ratio (Note 5) VCM = V– – 0.1V to V+ – 1.5V 128 150 dB –40°C to 125°C l 126 dB PSRR Power Supply Rejection Ratio (Note 5) VS = 4.75V to 36V 133 160 dB –40°C to 125°C l 129 dB AVOL Open Loop Voltage Gain (Note 5) VOUT = V– +0.25V to V+ –0.25V, RL =10kΩ 130 150 dB –40°C to 125°C l 128 dB VOL – V– Output Voltage Swing Low No Load 2 12 mV –40°C to 125°C l 45 mV ISINK = 1mA 35 60 mV –40°C to 125°C l 100 mV ISINK = 5mA 175 255 mV –40°C to 85°C l 360 mV –40°C to 125°C l 435 mV V+ – VOH Output Voltage Swing High No Load 3 15 mV –40°C to 125°C l 45 mV ISOURCE = 1mA 50 75 mV –40°C to 125°C l 125 mV ISOURCE = 5mA 235 335 mV –40°C to 85°C l 465 mV –40°C to 125°C l 560 mV ISC Short Circuit Current 19 30 mA SRRISE Rising Slew Rate AV = –1, RL = 10kΩ 1.3 V/μs SRFALL Falling Slew Rate AV = –1, RL = 10kΩ 0.45 V/μs GBW Gain Bandwidth Product 1.5 MHz fC Internal Chopping Frequency 100 kHz IS Supply Current No Load 0.88 1.35 mA –40°C to 85°C l 1.65 mA –40°C to 125°C l 1.83 mA In Shutdown Mode 3 μA –40°C to 85°C l 8 μA –40°C to 125°C l 9 μA VSDL Shutdown Threshold (SD – SDCOM) Low –40°C to 125°C l 0.8 V VSDH Shutdown Threshold (SD – SDCOM) High –40°C to 125°C l 2 V SDCOM Voltage Range –40°C to 125°C l V– V+ –2V V ISD SD Pin Current –40°C to 125°C, VSD – VSDCOM = 0 l –2.0 –0.5 µA ISDCOM SDCOM Pin Current –40°C to 125°C, VSD – VSDCOM = 0 l 0.5 2 µA 2057f For more information www.linear.com/LTC2057 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Applications Information Typical Applications Package Description Typical Application Related Parts
