Datasheet LTC6087, LTC6088 (Analog Devices)
DescriptionDual/Quad 14MHz, Rail-to-Rail CMOS Amplifiers
Pages / Page16 / 1 — FEATURES. DESCRIPTION. Low Offset Voltage: 750µV Maximum. Low Offset …
File Format / SizePDF / 308 Kb
FEATURES. DESCRIPTION. Low Offset Voltage: 750µV Maximum. Low Offset Drift: 5µV/°C Maximum. Input Bias Current:
Datasheet LTC6087, LTC6088 Analog Devices
LTC6087/LTC6088 Dual/Quad 14MHz, Rail-to-Rail CMOS Amplifiers
FEATURES DESCRIPTION
n
The LTC®6087/LTC6088 are dual/quad, low noise, low n
offset, rail-to-rail input/output, unity-gain stable CMOS n
Input Bias Current:
operational amplifiers that feature 1pA of input bias current.
1pA (Typical at 25°C)
A 14MHz gain bandwidth and 7.2V/µs slew rate, combined
15pA (Typical at 85°C)
with low noise (10nV/√Hz) and a low 0.75mV offset, make n
Rail-to-Rail Inputs and Outputs
the LTC6087/LTC6088 useful in a variety of applications. n Gain Bandwidth Product: 14MHz The 1.05mA supply current and the shutdown mode are n CMRR: 70dB Minimum ideal for signal processing applications which demand n PSRR: 93dB Minimum performance with minimal power. n Input Noise Voltage Density: 12nV/√Hz The LTC6087/LTC6088 has an output stage which swings n Supply Current: 1.05mA per Amp within 30mV of either supply rail to maximize signal dy- n Shutdown Current: 2.3µA per Amp namic range in low supply applications. The input common n 2.7V to 5.5V Operation Voltage mode range includes the entire supply voltage. These op n Available in 8-Lead MSOP and 10-Lead DFN amps are specified on power supply voltages of 3V and Packages (LTC6087), 16-Lead SSOP and DFN 5V from –40°C to 125°C. Packages (LTC6088) The dual amplifier LTC6087 is available in 8-lead MSOP
and 10-lead DFN packages. The quad amplifier LTC6088 is available in 16-lead SSOP and DFN packages. n Portable Test Equipment L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Analog n Medical Equipment Devices, Inc. All other trademarks are the property of their respective owners. n Audio n Data Acquisition n High Impedance Transducer Amplifier
TYPICAL APPLICATION LTC6087 Input Bias Current Single Supply Shock/Vibration Sensor Amplifier vs Temperature
1000 VS = 5V V MURATA SHOCK CM = 2.5V VS SENSOR PKGS-00MX1 VS 520pF, 0.57pC/g 100k 100 + www.murata.com + V 100k 0.1µF 1/2 LTC6087 1/2 LTC6087 OUT 570mV/g – – 16Hz TO 10kHz 10 100M VS = 2.7V TO 5.5V 1k 100k INPUT BIAS CURRENT (pA) 1% 100pF 1% 60878 TA01a 1 25 40 55 70 85 100 115 130 TEMPERATURE (°C) 60878 TA01b 60878fd For more information www.linear.com/LTC6087 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Simplified Schematic Package Description Revision History Typical Applications Related Parts
