Datasheet LT6003, LT6004, LT6005 (Analog Devices) - 2
Description1.6V, 1µA Precision Rail-to-Rail Input and Output Op Amps
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION
LT6003/LT6004/LT6005
Total Supply Voltage (V+ to V–) ...18V Specified Temperature Range (Note 4) Differential Input Voltage...18V LT6003C, LT6004C, LT6005C ... 0°C to 70°C Input Voltage Below V– ...9V LT6003I, LT6004I, LT6005I ... –40°C to 85°C Input Current ..10mA LT6003H, LT6004H, LT6005H ... –40°C to 125°C Output Short Circuit Duration (Note 2)... Indefinite Junction Temperature Operating Temperature Range (Note 3) DFN Packages ... 125°C LT6003C, LT6004C, LT6005C ... –40°C to 85°C All Other Packages .. 150°C LT6003I, LT6004I, LT6005I ... –40°C to 85°C Storage Temperature Range LT6003H, LT6004H, LT6005H ... –40°C to 125°C DFN Packages .. –65°C to 125°C All Other Packages ... –65°C to 150°C Lead Temperature (Soldering, 10 sec) TSOT, MSOP, SSOP Packages ... 300°C
PIN CONFIGURATION
LT6003 LT6003 LT6004 TOP VIEW TOP VIEW +IN 1 TOP VIEW OUT A 1 8 V+ –IN 2 OUT 1 5 V+ –IN A 2 – 7 OUT B – + A+ 9 OUT 3 + – +IN A 3 – 6 –IN B 5 V– 2 B+ V+ 4 +IN 3 4 –IN V– 4 5 +IN B DC PACKAGE S5 PACKAGE 4-LEAD (2mm × 2mm) PLASTIC DFN 5-LEAD PLASTIC TSOT-23 DD PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 125°C, θJA = 102°C/W (NOTE 2) TJMAX = 150°C, θJA = 250°C/W T EXPOSED PAD (PIN 5) IS V–, JMAX = 125°C, θJA = 160°C/W (NOTE 2) EXPOSED PAD (PIN 9) CONNECTED TO V– MUST BE SOLDERED TO PCB (PCB CONNECTION OPTIONAL) LT6004 LT6005 LT6005 TOP VIEW TOP VIEW OUT A 1 16 OUT D –IN A 2 – – 15 –IN D OUT A 1 16 OUT D + A D + –IN A 2 – – 15 –IN D TOP VIEW +IN A 3 14 +IN D + A D + +IN A 3 14 +IN D OUT A 1 8 V+ V+ 4 13 V– –IN A 2 – 17 V+ 4 13 V– + 7 OUT B +IN B 5 + + 12 +IN C +IN A 3 – + 6 –IN B – B C – V– +IN B 5 + + 12 +IN C 4 5 +IN B –IN B 6 11 –IN C – B C –IN B 6 – 11 –IN C MS8 PACKAGE OUT B 7 10 OUT C 8-LEAD PLASTIC MSOP NC 8 9 NC OUT B 7 10 OUT C NC 8 9 NC TJMAX = 150°C, θJA = 250°C/W DHC PACKAGE 16-LEAD (5mm × 3mm) PLASTIC DFN GN PACKAGE 16-LEAD PLASTIC SSOP TJMAX = 125°C, θJA = 160°C/W (NOTE 2) TJMAX = 150°C, θJA = 135°C/W EXPOSED PAD (PIN 17) CONNECTED TO V–, (PCB CONNECTION OPTIONAL) 600345fd 2
