Datasheet LT6010 (Analog Devices) - 8
Description | 135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp with Shutdown |
Pages / Page | 16 / 8 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. … |
File Format / Size | PDF / 304 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage. Warm-Up Drift. THD + Noise vs Frequency
LT6010
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current vs Supply Voltage Warm-Up Drift THD + Noise vs Frequency
500 3 10 VS = 5V, 0V 450 VOUT = 2VP-P µV) TA = 25°C 400 1 AV = 1: RL = 10k µA) ±15V 350 T AV = –1: RF = RG = 10k A = 85°C 2 300 0.1 TA = 25°C 250 200 ±2.5V 0.01 1 THD + NOISE (%) AV = –1 150 T SUPPLY CURRENT ( A = –40°C AV = 1 100 0.001 CHANGE IN OFFSET VOLTAGE ( 50 0 0 0.0001 0 2 4 6 8 10 12 14 16 18 20 30 60 90 120 150 10 100 1k 10k 100k SUPPLY VOLTAGE (±V) TIME AFTER POWER-ON (SECONDS) FREQUENCY (Hz) 6010 G13 6010 G14 6010 G15
THD + Noise vs Frequency Settling Time vs Output Step Settling Time vs Output Step
10 10 10 V V V S = ±15V S = ±15V S = ±15V V A A IN = 20VP-P V = 1 V = –1 T 1 A = 25°C 8 8 0.1 6 6 0.1% 0.1% 0.01% 0.01% 0.01 AV = –1 4 4 THD + NOISE (%) A OUTPUT STEP (V) OUTPUT STEP (V) V = 1 0.001 2 2 0.0001 0 0 10 100 1k 10k 0 10 20 30 40 50 60 70 80 90 0 10 20 30 40 50 60 70 80 90 FREQUENCY (Hz) SETTLING TIME (µs) SETTLING TIME (µs) 6010 G16 6010 G17 6010 G18
CMRR vs Frequency PSRR vs Frequency
160 140 TA = 25°C VS = 5V, 0V T 140 A = 25°C 120 120 100 100 80 80 VS = ±15V +PSRR VS = 5V, 0V 60 60 –PSRR 40 40 20 20 COMMON MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) 0 0 1 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) 6010 G20 6010 G21 sn6010 6010fs 8
