Datasheet LT1462, LT1463 (Analog Devices)
DescriptionDual/Quad Micropower, 260µW C-Load Picoampere Bias Current JFET Input Op Amps
Pages / Page12 / 1 — FEATURES. DESCRIPTION. Input Bias Current:. 2pA Max (LT1462A). 20pA Max …
File Format / SizePDF / 288 Kb
FEATURES. DESCRIPTION. Input Bias Current:. 2pA Max (LT1462A). 20pA Max (LT1462, LT1463). Supply Current per Amplifier: 45. A Max
Datasheet LT1462, LT1463 Analog Devices
LT1462/LT1463 Dual/Quad Micropower, 260µW C-Load Picoampere Bias Current JFET Input Op Amps
U FEATURES DESCRIPTION
Input Bias Current:
The LT ®1462 (dual) and LT1463 (quad) are the first
2pA Max (LT1462A)
micropower op amps (45µA max per amp) to offer
picoampere input bias currents (1pA typ) and unity gain ■
µ
A Max
stability for capacitive loads up to 10nF. The output can ■ Unity-Gain Stable for C-LoadTM Up to 10nF swing a 10k load to within 1.5V of either supply, just like ■ Input Common Mode Range Includes Positive Rail op amps that require an order of magnitude more supply ■ Guaranteed Specs with ±5V, ±15V Supplies current. This unique combination of performance makes ■ Gain Bandwidth Product: 175kHz Typ the LT1462/LT1463 ideal over a wide range of input and ■ Slew Rate: 0.13V/µs Typ output impedances. ■ Guaranteed Matching Specifications In the design and testing of the LT1462/LT1463, particular ■ Standard Pinout: SO-8, SO-14 Package emphasis has been placed on optimizing performance in
U
the low cost SO-8 (dual) and 14-lead SO package (quad) for
±15V and ±5V supplies. The input common mode range includes the positive rail. Slew rate (0.08V/µs min) and gain ■ Battery-Powered Systems bandwidth product (125kHz min) are 100% tested. A full set ■ Photocurrent Amplifiers of matching specifications is also provided. ■ Low Frequency, Micropower Active Filters , LTC and LT are registered trademarks of Linear Technology Corporation. ■ Low Droop Track-and-Hold Circuits C-Load is a trademark of Linear Technology Corporation.
U TYPICAL APPLICATION Low Power Logging Amplifier
R8 Q1 100k 2N3904 D1 C5
Small-Signal Response, C
1N4148 1µF R9
L = 10nF
1M C1 R5 DC 1nF 24k OUT C3 5 + 0.47µF C5 AMP 3 7 R1 5V 1/4 LT1463 100Ω 2 – 200pF 6 4 – C4 R7 10 R10 1 + 10µF 1/4 LT1463 10M 50k AC 3 + 8 1/4 LT1463 D3 OUT 11 9 1N4148 – R3 –5V 10k R11 PHOTODIODE R6 1M R2 100k 24k 12 R12 1462 • TA01 + 1462 • TA02 10k AV = 1
INPUT DC OUTPUT
C2 14 1/4 LT1463 VS = ±5V, ±15V
CURRENT VOLTAGE OF AMP 3
200pF 13 CL = 10nF – 10pA –0.145V R4 100pA –0.341V 10M 1nA –0.518V 10nA –0.684V D2 100nA –0.846V 1N4148 1 µA –0.995V 10 µA –1.13V 100 µA –1.25V R3 1mA –1.37V 100k 1
