Datasheet LTC1250 (Analog Devices) - 2
DescriptionVery Low Noise Zero-Drift Bridge Amplifier
Pages / Page12 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). (OBSOLETE) .. PACKAGE/ORDER I FOR ATIO. …
File Format / SizePDF / 184 Kb
ABSOLUTE AXI U. RATI GS (Note 1). (OBSOLETE) .. PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) . PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE ELECTRICAL CHARACTERISTICS The
LTC1250
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Total Supply Voltage (V+ to V –) ... 18V Operating Temperature Range Input Voltage .. (V + + 0.3V) to (V – – 0.3V) LTC1250M
(OBSOLETE) ..
– 55°C to 125°C Output Short Circuit Duration ... Indefinite LTC1250C .. 0°C TO 70°C Storage Temperature Range .. – 65°C to 150°C Lead Temperature (Soldering, 10 sec.).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART NC NUMBER 1 8 NC NUMBER TOP VIEW –IN 2 7 V+ LTC1250CN8 LTC1250CS8 +IN 3 6 OUT NC 1 8 NC V – 4 5 NC –IN 2 7 V+ +IN 3 6 OUT N8 PACKAGE 8-LEAD PLASTIC DIP V – 4 5 NC S8 PART MARKING TJMAX = 110°C, θJA = 130°CW S8 PACKAGE J8 PACKAGE 8-LEAD PLASTIC SO 8-LEAD CERAMIC DIP LTC1250MJ8 1250 T T JMAX = 110°C, θJA = 200°CW JMAX = 150°C, θJA = 100°CW (J8) LTC1250CJ8
OBSOLETE PACKAGE
Consider the N8 or S8 for Alternative Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range, VIN =
5V, otherwise specifications are at TA = 25
C. LTC1250M LTC1250C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage TA = 25°C (Note 2) ±5 ±10 ±5 ±10 µV ∆VOS Average Input Offset Drift (Note 2) ● ±0.01 ±0.05 ±0.01 ±0.05 µV/°C Long Term Offset Drift 50 50 nV/√Mo en Input Noise Voltage (Note 3) TA = 25°C, 0.1Hz to 10Hz 0.75 1.0 0.75 1.0 µVP-P TA = 25°C, 0.1Hz to 1Hz 0.2 0.2 µVP-P in Input Noise Current f = 10Hz 4.0 4.0 fA/√Hz IB Input Bias Current TA = 25°C (Note 4) ±50 ±150 ±50 ±200 pA ● ±950 ±450 pA IOS Input Offset Current TA = 25°C (Note 4) ±100 ±300 ±100 ±400 pA ● ±500 ±500 pA CMRR Common Mode Rejection Ratio VCM = – 4V to 3V ● 110 130 110 130 dB PSRR Power Supply Rejection Ratio VS = ±2.375V to ±8V ● 115 130 115 130 dB AVOL Large-Signal Voltage Gain RL = 10k, VOUT = ±4V ● 125 170 125 170 dB Maximum Output Voltage Swing RL = 1k ● ±4.0 4.3/–4.7 ±4.0 4.3 /–4.7 V RL = 100k ±4.92 ±4.95 V SR Slew Rate RL = 10k, CL = 50pF 10 10 V/µs GBW Gain-Bandwidth Product 1.5 1.5 MHz IS Supply Current No Load, TA = 25°C 3.0 4.0 3.0 4.0 mA ● 7.0 5.0 mA 1250fb 2
