Datasheet LTC1151 (Analog Devices) - 3
DescriptionDual ±15V Zero-Drift Operational Amplifier
Pages / Page12 / 3 — ELECTRICAL CH. ARA TERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 190 Kb
ELECTRICAL CH. ARA TERISTICS The. denotes the specifications which apply over the full operating
ELECTRICAL CH ARA TERISTICS The denotes the specifications which apply over the full operating
LTC1151
ELECTRICAL CH C ARA TERISTICS The
C. VS =
15V, unless otherwise specified. LTC1151C PARAMETER CONDITIONS MIN TYP MAX UNITS
Maximum Output Voltage Swing RL = 10k, TA = 25°C ±13.5 ±14.50 V RL = 10k ● +10.5/–13.5 V RL = 100k ±14.95 V Slew Rate RL = 10k, CL = 50pF 2.5 V/µs Gain-Bandwidth Product 2 MHz Supply Current per Amplifier No Load, TA = 25°C 0.9 1.5 mA No Load ● 2.0 mA Internal Sampling Frequency 1000 Hz
The
C. VS = 5V, unless otherwise specified.
Input Offset Voltage TA = 25°C (Note 3) ±0.05 ±5 µV Average Input Offset Drift (Note 3) ● ±0.01 ±0.05 µV/°C Long Term Offset Voltage Drift 50 nV/√mo Input Offset Current TA = 25°C ±10 100 pA Input Bias Current TA = 25°C ±5 50 pA Input Noise Voltage RS = 100Ω, 0.1Hz to 10Hz 2.0 µVP-P RS = 100Ω, 0.1Hz to 1Hz 0.7 µVP-P Input Noise Current f = 10Hz (Note 4) 1.3 fA/√Hz Input Voltage Range Positive 2.7 3.2 V Negative 0 – 0.3 V Common Mode Rejection Ratio VCM = 0V to 2.7V 110 dB Power Supply Rejection Ratio VS = ±2.375V to ±16V ● 110 130 dB Large-Signal Voltage Gain RL = 10k, VOUT = 0.3V to 4.5V ● 115 140 dB Maximum Output Voltage Swing RL = 10k to GND 4.85 V RL = 100k to GND 4.97 V Slew Rate RL = 10k, CL = 50pF 1.5 V/µs Gain Bandwidth Product 1.5 MHz Supply Current per Amplifier No Load, TA = 25°C 0.5 1.0 mA ● 1.5 mA Internal Sampling Frequency 750 Hz
Note 1:
Note 3:
These parameters are guaranteed by design. Thermocouple effects of a device may be impaired. preclude measurement of these voltage levels in high speed automatic test
Note 2:
Connecting any terminal to voltages greater than V+ or less than V– systems. VOS is measured to a limit determined by test equipment may cause destructive latch-up. It is recommended that no sources capability. operating from external supplies be applied prior to power-up of the
Note 4:
Current Noise is calculated from the formula: LTC1151. IN = √(2q • Ib) where q = 1.6 × 10–19 Coulomb. 1151fa 3
