Datasheet LTC1150 (Analog Devices) - 5
Description | ±15V Zero-Drift Operational Amplifier with Internal Capacitors |
Pages / Page | 16 / 5 — TYPICAL PERFOR A CE CHARACTERISTICS. Input Bias Current vs Supply. … |
File Format / Size | PDF / 245 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. Input Bias Current vs Supply. Undistorted Output Swing vs. Voltage. Frequency
LTC1150
W U TYPICAL PERFOR A CE CHARACTERISTICS Input Bias Current vs Supply Undistorted Output Swing vs Voltage Frequency Gain/Phase vs Frequency
12 30 120 60 T V A = 25°C S = ±2.5V V C CM = OV 100 L = 100pF 80 10 25 PIN 1 = V– PHASE 80 100 RL = 10k PHASE (DEGREES) GAIN 8 20 60 120 6 15 40 140 PIN 1 = FLOATING R GAIN (dB) L = 100k 20 160 4 10 INPUT BIAS CURRENT (pA) OUTPUT VOLTAGE (Vp-p) 0 180 2 5 –20 200 0 0 –40 220 0 ± 2 ± 4 ± 6 ± 8 ± 10 ± 12 ± 14 ± 16 100 1k 10k 100k 1M 100 1k 10k 100k 1M 10M SUPPLY VOLTAGE (V) FREQUENCY (Hz) FREQUENCY (Hz) LTC1150 • TPC07 LTC1150 • TPC08 LTC1150 • TPC09
Input Bias Current vs Input Common Mode Input Range vs Common Mode Voltage Input Bias Current vs Temperature Supply Voltage
40 –1000 15 VS = ± 15V VCM = 0 TA = 25°C 30 TA = 25°C VS = ± 15V 10 20 –IB –100 5 10 0 0 –I –10 B +IB +I –10 –5 B INPUT BIAS CURRENT (pA) –20 INPUT BIAS CURRENT (pA) COMMON MODE RANGE (V) –10 –30 –40 –1 –15 –15 –10 –5 0 5 10 15 –50 –25 0 25 50 75 100 125 0 ±2.5 ±5 ±7.5 ±10 ±12.5 ±15 INPUT COMMON MODE VOLTAGE (V) SUPPLY VOLTAGE (V) TEMPERATURE (°C) LTC1150 • TPC11 LTC1150 • TPC12 LTC1150 • TPC10
Offset Voltage vs CMRR vs Frequency PSRR vs Frequency Sampling Frequency
160 160 10 POSITIVE SUPPLY, PIN 1 = OPEN VA = ± 15V 140 140 TA = 25°C 8 120 120 PIN 1 = V– POSITIVE SUPPLY, V) µ 100 100 PIN 1 = V– 6 80 80 CMRR (dB) PSRR (dB) 60 60 4 NEGATIVE SUPPLY, PIN 1 = OPEN PIN 1 = OPEN 40 40 OFFSET VOLTAGE ( 2 20 20 NEGATIVE SUPPLY, PIN 1 = V– 0 0 0 1 10 100 1k 10k 100k 1 10 100 1k 10k 100k 0 1k 2k 3k FREQUENCY (Hz) FREQUENCY (Hz) SAMPLING FREQUENCY, fS (Hz) LTC1150 • TPC13 LTC1150 • TPC14 LTC1150 • TPC15 1150fb 5
