Datasheet LTC1050 (Analog Devices) - 2
DescriptionPrecision Zero-Drift Operational Amplifier with Internal Capacitors
Pages / Page16 / 2 — ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
File Format / SizePDF / 232 Kb
ABSOLUTE. AXI U. R TI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE. ELECTRICAL CH. ARA TERISTICS The
ABSOLUTE AXI U R TI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE ELECTRICAL CH ARA TERISTICS The
LTC1050
W W W U ABSOLUTE AXI U A R TI GS (Note 1)
Total Supply Voltage (V+ to V–) .. 18V Operating Temperature Range Input Voltage .. (V+ + 0.3V) to (V– – 0.3V) LTC1050AC/C .. – 40°C to 85°C Output Short-Circuit Duration ... Indefinite LTC1050H ... – 40°C to 125°C Storage Temperature Range .. – 65°C to 150°C LTC1050AM/M
(OBSOLETE)
.. – 55°C to 125°C Lead Temperature (Soldering, 10 sec)... 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART NC NUMBER NUMBER 8 TOP VIEW NC 1 7 V+ (CASE) LTC1050ACH NC 1 8 NC LTC1050CS8 –IN 2 6 OUT LTC1050CH – –IN 2 7 V+ LTC1050HS8 LTC1050AMH + +IN 3 6 OUT +IN 3 5 EXT CLOCK 4 INPUT LTC1050MH V– 4 5 EXT CLOCK V – INPUT S8 PART MARKING H PACKAGE S8 PACKAGE 8-LEAD TO-5 METAL CAN 8-LEAD PLASTIC SO 1050 TJMAX = 150°C TJMAX = 150°C, θJA = 150°C/W 1050H
OBSOLETE PACKAGE
TOP VIEW ORDER PART ORDER PART TOP VIEW NUMBER NUMBER NC 1 8 NC NC 1 14 NC –IN 2 7 V+ LTC1050ACN8 NC 2 13 NC LTC1050CN +IN 3 6 OUT LTC1050CN8 NC 3 12 NC V– 4 5 EXT CLOCK –IN 4 11 V+ INPUT N8 PACKAGE +IN 5 10 OUT LTC1050ACJ8 8-LEAD PDIP NC 6 9 NC LTC1050CJ8 TJMAX = 150°C, θJA = 100°C/W V – 7 8 NC LTC1050AMJ8 J8 PACKAGE 8-LEAD CERDIP T N PACKAGE JMAX = 150°C, θJA = 100°C/W LTC1050MJ8 14-LEAD PDIP
OBSOLETE PACKAGE
TJMAX = 150°C, θJA = 70°C/W Consider the N8 Package for Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CH C ARA TERISTICS The
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS =
5V LTC1050AM LTC1050AC PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Offset Voltage (Note 3) ±0.5 ±5 ±0.5 ±5 µV Average Input Offset Drift (Note 3) ● ±0.01 ±0.05 ±0.01 ±0.05 µV/°C Long Term Offset Voltage Drift 50 50 nV/√Mo Input Offset Current (Note 5) ±20 ±60 ±20 ±60 pA ● ±300 ±150 pA Input Bias Current (Note 5) ±10 ±30 ±10 ±30 pA ● ±2000 ±100 pA Input Noise Voltage 0.1Hz to 10Hz (Note 6) 1.6 2.1 1.6 2.1 µVP-P DC to 1Hz 0.6 0.6 µVP-P 1050fb 2
