Datasheet LT1057, LT1058 (Analog Devices)
DescriptionDual and Quad, JFET Input Precision High Speed Op Amps
Pages / Page16 / 1 — FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Current Output, …
File Format / SizePDF / 340 Kb
FEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Current Output, High Speed, High Input Impedance
Datasheet LT1057, LT1058 Analog Devices
LT1057/LT1058 Dual and Quad, JFET Input Precision High Speed Op Amps
FEATURES DESCRIPTION
n 14V/µs Slew Rate: 10V/µs Min The LT®1057 is a matched JFET input dual op amp in n 5MHz Gain-Bandwidth Product the industry standard 8-pin configuration, featuring a n Fast Settling Time: 1.3µs to 0.02% combination of outstanding high speed and precision n 150µV Offset Voltage (LT1057): 450µV Max specifications. It replaces all the popular bipolar and JFET n 180µV Offset Voltage (LT1058): 600µV Max input dual op amps. In particular, the LT1057 upgrades the n 2µV/°C VOS Drift: 7µV/°C Max performance of systems using the LF412A and OP-215 n 50pA Bias Current at 70°C JFET input duals. n Low Voltage Noise: The LT1058 is the lowest offset quad JFET input operational 13nV/√Hz at 1kHz amplifier in the standard 14-pin configuration. It offers 26nV/√Hz at 10Hz significant accuracy improvement over presently available JFET input quad operational amplifiers. The LT1058 can
replace four single precision JFET input op amps, while saving board space, power dissipation and cost. n Precision, High Speed Instrumentation n Both the LT1057 and LT1058 are available in the plastic Fast, Precision Sample-and-Hold n PDIP package and the surface mount SO package. Logarithmic Amplifiers n D/A Output Amplifiers , LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners. n Photodiode Amplifiers n Voltage-to-Frequency Converters n Frequency-to-Voltage Converters
TYPICAL APPLICATION Current Output, High Speed, High Input Impedance Distribution of Offset Voltage Instrumentation Amplifier (All Packages, LT1057 and LT1058)
25 3 V LT1057: 610 OP AMPS V2 + S = ±15V LT1058: 520 OP AMPS 1 7.5k T 1/4 A = 25°C 1130 OP AMPS LT1058 20 TESTED 2 2(V1 – V2) – IOUT = 4.7k 7.5k RX 6 – 15 RX 1/4 7 9.1k LT1058 IOUT 5 + 10 500Ω* + 10 PERCENT OF UNITS 8 1/4 LT1058 5 13 4.7k – 9 – 1/4 14 7.5k 6.8k 0 LT1058 –1.0 –0.6 –0.2 0 0.2 0.6 1.0 12 1k** V1 + INPUT OFFSET VOLTAGE (mV) 10578 TA01b *GAIN ADJUST **COMMON MODE REJECTION ADJUST BANDWIDTH ≈ 2MHz 10578 TA01 10578fd 1 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
