Datasheet LT8610AX (Analog Devices) - 5
Description42V, 3.5A Synchronous Step-Down Regulator with Operation to 175°C
Pages / Page6 / 5 — APPLICATIONS INFORMATION. PACKAGE DESCRIPTION
File Format / SizePDF / 525 Kb
APPLICATIONS INFORMATION PACKAGE DESCRIPTION
LT8610AX
For Application Information, Block Diagram, and Typical Performance Curves from –40°C to 150°C range, please see the LT8610A/LT8610AB Series data sheet. The LT8610AX will perform similarly to the LT8610AB. The LT8610AX has no thermal shutdown.
PACKAGE DESCRIPTION Please refer to http://www.linear.com/product/LT8610AX#packaging for the most recent package drawings. MSE Package 16-Lead Plastic MSOP, Exposed Die Pad
(Reference LTC DWG # 05-08-1667 Rev F) BOTTOM VIEW OF EXPOSED PAD OPTION 2.845 ±0.102 2.845 ±0.102 (.112 ±.004) 0.889 ±0.127 (.112 ±.004) (.035 ±.005) 1 8 0.35 REF 5.10 1.651 ±0.102 (.201) 1.651 ±0.102 3.20 – 3.45 0.12 REF MIN (.065 ±.004) (.126 – .136) (.065 ±.004) DETAIL “B” CORNER TAIL IS PART OF DETAIL “B” THE LEADFRAME FEATURE. 16 9 FOR REFERENCE ONLY 0.305 ±0.038 0.50
NO MEASUREMENT PURPOSE
(.0120 ±.0015) (.0197) 4.039 ±0.102 TYP BSC (.159 ±.004) (NOTE 3) RECOMMENDED SOLDER PAD LAYOUT 0.280 ±0.076 16151413121110 9 (.011 ±.003) REF DETAIL “A” 0.254 (.010) 0° – 6° TYP 3.00 ±0.102 4.90 ±0.152 (.118 ±.004) GAUGE PLANE (.193 ±.006) (NOTE 4) 0.53 ±0.152 (.021 ±.006) 1 2 3 4 5 6 7 8 DETAIL “A” 1.10 0.86 0.18 (.043) (.034) (.007) MAX REF SEATING PLANE 0.17 – 0.27 0.1016 ±0.0508 (.007 – .011) (.004 ±.002) TYP 0.50 MSOP (MSE16) 0213 REV F NOTE: (.0197) 1. DIMENSIONS IN MILLIMETER/(INCH) BSC 2. DRAWING NOT TO SCALE 3. DIMENSION DOES NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. MOLD FLASH, PROTRUSIONS OR GATE BURRS SHALL NOT EXCEED 0.152mm (.006") PER SIDE 4. DIMENSION DOES NOT INCLUDE INTERLEAD FLASH OR PROTRUSIONS. INTERLEAD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.152mm (.006") PER SIDE 5. LEAD COPLANARITY (BOTTOM OF LEADS AFTER FORMING) SHALL BE 0.102mm (.004") MAX 6. EXPOSED PAD DIMENSION DOES INCLUDE MOLD FLASH. MOLD FLASH ON E-PAD SHALL NOT EXCEED 0.254mm (.010") PER SIDE. 8610axf Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the inter For mo connection re of in its fo cir rma cuits tion www.l as described inear. herein com will /L not T8610 infringe AX on existing patent rights. 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Related Parts
