15 /10 — ADP2360. Data Sheet. THEORY OF OPERATION. VIN. CIN. VIN 8. VREG. UVLO. …
Revision
A
PDF / 674 Kb
ADP2360. Data Sheet. THEORY OF OPERATION. VIN. CIN. VIN 8. VREG. UVLO. 0µA TO. BAND GAP. TSD. 0.8V. 5µA. ITH. VITH. IPEAK. COMPARATOR. ADJUSTABLE OUTPUT
ADP2360Data SheetTHEORY OF OPERATIONVINCINVIN 8VREGBGUVLOUVLO0µA TOBAND GAPTSDTSD0.8V5µAITHVREGVREG3gRMITHVITHIPEAKVREGCOMPARATORADJUSTABLE OUTPUTADP2360VOLTAGE1µAIVPEAKOUTSSCONTROL5LEVELR1FBCSHIFTSS4SWL1R2V7OUTCOUTFEEDBACKCONTROLLOGICCOMPARATOR0.8VFIXED OUTPUTVOLTAGEZERO CROSSINGPGNDDETECTORFB6UVLOCOMPARATOR4VOUTTSDR1VINRPGR2VPGENPG_RISING21POWER GOODENABLECOMPARATORVEN_RISING9 AGNDNOTES 21 1. THE PORTIONS IN THE DASHED BOXES DISPLAY THE DIFFERENCE OF THE FUNCTIONALITY OF PIN 4 0 44- FOR THE ADJUSTABLE AND FIXED OUTPUT VOLTAGES. 139 Figure 21. Block Diagram OVERVIEW When the PMOS turns off, the NMOS turns on, reducing the The ADP2360 is a high efficiency, high input voltage, DCM energy stored in the inductor until the inductor current reaches synchronous, step-down, dc-to-dc switching regulator. zero. At this point, the NMOS also turns off. The ADP2360 uses a single-pulse PFM architecture with adjustable When both the NMOS and PMOS are off, the ADP2360 enters I into sleep mode. During this phase of operation, the stored energy PEAK control to adjust the frequency variation within the application and to minimize the input and output ripple. in COUT delivers the load current, and thus VOUT and VFB decrease. When VFB drops below the VFB_FALLING threshold, another The ADP2360 further offers a power-good (PG) pin with an switching cycle begins. open-drain output signal to indicate when the output voltage is stable. Other key features include 100% duty cycle operation, IPEAK precision enable control, external soft start control, undervoltage ItSLEEPL lockout, and thermal shutdown. CONTROL SCHEME The ADP2360 uses a single-pulse, peak current PFM control PMOS scheme. A switching cycle is started when the FB pin voltage, VFB, is less than the VFB_FALLING threshold, and the PMOS is turned NMOS on. While the PMOS is on, the current through the inductor increases to charge the output capacitor (COUT) and store energy FBVFB_FALLING in the inductor. The current through the inductor continues to increase until it reaches the IPEAK programmed via the ITH pin. When I V PEAK is reached, or if the VFB voltage rises above VFB_RISING, OUT -022 the PMOS turns off. 44 139 Figure 22. Control Scheme Typical Waveforms Rev. A | Page 10 of 15 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OVERVIEW CONTROL SCHEME 100% Duty Cycle Adjustable Peak Current Threshold (ITH) DEVICE FEATURES Fixed and Adjustable Output Models Shutdown/Precision Enable Soft Start Thermal Shutdown (TSD) Undervoltage Lockout (UVLO) Power Good APPLICATIONS INFORMATION SETTING THE OUTPUT VOLTAGE INPUT CAPACITOR SELECTION ESTIMATING THE SWITCHING FREQUENCY SETTING THE PEAK INDUCTOR CURRENT INDUCTOR SELECTION OUTPUT CAPACITOR SELECTION DESIGN OPTIMIZATION RECOMMENDED COMPONENTS PCB LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
