Datasheet LT3995 (Analog Devices) - 2
Description60V, 3A, 2MHz Step-Down Switching Regulator with 2.7μA Quiescent Current
Pages / Page24 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 356 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3995
V TOP VIEW IN, EN Voltage (Note 3) ...60V BOOST Pin Voltage ...75V FB 1 16 SYNC SS 2 15 PG BOOST Pin Above SW Pin ...30V OUT 3 14 RT BOOST 4 17 13 EN FB, RT, SYNC, SS Voltage ...6V SW 5 GND 12 VIN SW 6 11 VIN PG Voltage ..30V SW 7 10 VIN NC 8 9 NC OUT Voltage ..16V MSE PACKAGE Operating Junction Temperature Range (Note 2) 16-LEAD PLASTIC MSOP LT3995E .. –40°C to 125°C θJA = 40°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB LT3995I ... –40°C to 125°C LT3995H .. –40°C to 150°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ...300°C
LT3995EMSE#PBF LT3995EMSE#TRPBF 3995 16-Lead Plastic MSOP –40°C to 125°C LT3995IMSE#PBF LT3995IMSE#TRPBF 3995 16-Lead Plastic MSOP –40°C to 125°C LT3995HMSE#PBF LT3995HMSE#TRPBF 3995 16-Lead Plastic MSOP –40°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 2) PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Input Voltage (Note 3) l 4 4.3 V Dropout Comparator Threshold (VIN – OUT) Falling 430 500 570 mV Dropout Comparator Threshold Hysteresis 25 mV Quiescent Current from VIN VEN Low 0.7 1.3 µA VEN High, VSYNC Low 1.6 2.7 µA VEN High, VSYNC Low l 30 µA FB Pin Current VFB = 1.5V l 0.1 12 nA Feedback Voltage 1.183 1.197 1.212 V l 1.173 1.197 1.222 V FB Voltage Line Regulation 4.3V < VIN < 60V (Note 3) 0.0003 0.01 %/V Switching Frequency RT = 11.8k 1.8 2.25 2.7 MHz RT = 41.2k 0.8 1 1.2 MHz RT = 294k 160 200 240 kHz Minimum Switch On-Time 130 ns Minimum Switch Off-Time (Note 4) 180 280 ns 3995f 2 For more information www.linear.com/LT3995 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
