Datasheet LTC3630 (Analog Devices) - 2
DescriptionHigh Efficiency, 65V 500mA Synchronous Step-Down Converter
Pages / Page26 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion …
File Format / SizePDF / 291 Kb
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3630
VIN Supply Voltage ... –0.3V to 70V Operating Junction Temperature Range (Notes 2, 3, 4) SW Voltage (DC) ... –0.3V to (VIN + 0.3V) LTC3630E, LTC3630I ... –40°C to 125°C RUN Voltage... –0.3V to 6V LTC3630H .. –40°C to 150°C SS, FBO, ISET Voltages ... –0.3V to 6V LTC3630MP ... –55°C to 150°C VFB, VPRG1, VPRG2 Voltages ... –0.3V to 6V Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) MSOP ...300°C
pin conFiguraTion
TOP VIEW SW 1 16 GND TOP VIEW NC 2 15 NC SW 1 16 GND VIN 3 14 GND V 3 IN 14 GND 17 NC 4 13 17 NC RUN 5 GND 12 FBO GND RUN 5 12 FBO V 6 PRG2 11 ISET V 7 PRG1 10 SS VPRG2 6 11 ISET GND 8 9 VFB VPRG1 7 10 SS MSE PACKAGE VARIATION: MSE16 (12) GND 8 9 VFB 16-LEAD PLASTIC MSOP TJMAX = 150°C, θJA = 45°C/W, θJC = 10°C/W DHC PACKAGE EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB 16-LEAD (5mm × 3mm) PLASTIC DFN (NOTE 6) TJMAX = 150°C, θJA = 43°C/W, θJC = 5°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3630EMSE#PBF LTC3630EMSE#TRPBF 3630 16-Lead Plastic MSOP –40°C to 125°C LTC3630IMSE#PBF LTC3630IMSE#TRPBF 3630 16-Lead Plastic MSOP –40°C to 125°C LTC3630HMSE#PBF LTC3630HMSE#TRPBF 3630 16-Lead Plastic MSOP –40°C to 150°C LTC3630MPMSE#PBF LTC3630MPMSE#TRPBF 3630 16-Lead Plastic MSOP –55°C to 150°C LTC3630EDHC#PBF LTC3630EDHC#TRPBF 3630 16-Lead (5mm × 3mm) Plastic DFN –40°C to 125°C LTC3630IDHC#PBF LTC3630IDHC#TRPBF 3630 16-Lead (5mm × 3mm) Plastic DFN –40°C to 125°C LTC3630HDHC#PBF LTC3630HDHC#TRPBF 3630 16-Lead (5mm × 3mm) Plastic DFN –40°C to 150°C LTC3630MPDHC#PBF LTC3630MPDHC#TRPBF 3630 16-Lead (5mm × 3mm) Plastic DFN –55°C to 150°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3630fd 2 For more information www.linear.com/LTC3630 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
