Datasheet LTC3879 (Analog Devices) - 5
Description | Fast, Wide Operating Range No RSENSE Step-Down Controller |
Pages / Page | 28 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Transient Response FCM. (Forced … |
File Format / Size | PDF / 314 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Transient Response FCM. (Forced Continuous Mode). Positive Load Step. Negative Load Step
LTC3879
TYPICAL PERFORMANCE CHARACTERISTICS Transient Response FCM Transient Response FCM Transient Response FCM (Forced Continuous Mode) Positive Load Step Negative Load Step
VSW VSW 20V/DIV 20V/DIV VOUT (AC) 50mV/DIV VOUT (AC) VOUT (AC) 50mV/DIV 50mV/DIV IL I 10A/DIV IL L 10A/DIV 10A/DIV ILOAD ILOAD ILOAD 10A/DIV 10A/DIV 10A/DIV 50μs/DIV 3879 G01 5μs/DIV 3879 G02 5μs/DIV 3879 G03 LOAD STEP 0A TO 10A TO 0A LOAD STEP 0A TO 10A LOAD STEP 10A TO 0A VIN = 12V VIN = 12V VIN = 12V VOUT = 1.2V VOUT = 1.2V VOUT = 1.2V MODE = 0V MODE = 0V MODE = 0V SW FREQ = 400kHz SW FREQ = 400kHz SW FREQ = 400kHz FIGURE 10 CIRCUIT FIGURE 10 CIRCUIT FIGURE 10 CIRCUIT
Transient Response DCM Normal Start-Up, RUN Pin Start-Up Into a Pre-Biased Output (Discontinuous Mode) Released from GND RUN Pin Released from GND
I RUN L V 5A/DIV OUT (AC) 5V/DIV 50mV/DIV VOUT V I OUT 0.5V/DIV L 0.5V/DIV 10A/DIV ILOAD TRACK/SS TRACK/SS 10A/DIV 0.5V/DIV 0.5V/DIV 3879 G05 50μs/DIV 3879 G04 20ms/DIV 20ms/DIV 3879 G06 LOAD STEP 1A TO 11A TO 1A VIN = 12V VIN = 12V VIN = 12V VOUT = 1.2V VOUT = 1.2V VOUT = 1.2V SW FREQ = 400kHz SW FREQ = 400kHz MODE = INTVCC FIGURE 10 CIRCUIT FIGURE 10 CIRCUIT SW FREQ = 400kHz FIGURE 10 CIRCUIT
Start-Up After Input Undervoltage Coincident Rail Tracking 1.2V VIN Cycled Low to High VOUT Tracks External 1.8V Supply Effi ciency vs Load Current
100 VIN VMASTER 90 DISCONTINUOUS 10V/DIV 0.5V/DIV MODE 80 TRACK/SS 5V/DIV 70 VOUT 0.5V/DIV 60 CONTINUOUS MODE VOUT 50 1V/DIV 40 EFFICIENCY (%) 100ms/DIV 3879 G07 5ms/DIV 3879 G08 30 VIN = 12V VIN = 12V VIN = 12V V 20 OUT = 1.2V VOUT = 1.2V VOUT = 1.2V SW FREQ = 400kHz SW FREQ = 400kHz 10 SW FREQ = 400kHz FIGURE 10 CIRCUIT FIGURE 10 CIRCUIT FIGURE 10 CIRCUIT 0 0.01 0.1 1 10 100 LOAD CURRENT (A) 3879 G09 3879f 5
